C3 Wheel bolt pattern
Old Sep 24, 2009 | 11:24 AM
joez74's Avatar
joez74
Default C3 Wheel bolt pattern
New to the game, what is the bolt pattern for a 74?
Will this fit:
15 in x 8 in., 5 x 4.5/4.75/5 in. Bolt Circle, 4.25 in. Backspace, -6.00mm offset.
Old Sep 24, 2009 | 11:58 AM
bashcraft's Avatar
bashcraft
5 X 4 3/4, 4" back space
Old Sep 24, 2009 | 07:51 PM
MN80Vette's Avatar
MN80Vette
The additional 1/4" of backspacing will set the tires inward that much on each side. That probably won't be a problem unless you put tires wider than 255 on those wheels. I have 255's on aftermarket wheels with 4.5" backspacing on my '80 with no problems.
Old Sep 24, 2009 | 08:00 PM
'75's Avatar
'75
Those wheels seem to have the uni lug patern, may not be the safest choice.
Old Sep 25, 2009 | 08:57 AM
joez74's Avatar
joez74
They're Crager SS's, I've seen them on tons of cars over the years and never heard of any problems. Can't you just get a set of lugs with washers for them? Or is it just an all together bad idea?
Old Sep 25, 2009 | 09:05 AM
'75's Avatar
'75
I don't know of any problems with the uni-lug wheels, but given the choice between those or a single patern specific to the car, just my opinion. If the center hole in the wheel is the correct size, I would feel better about them.
Old Sep 25, 2009 | 09:41 AM
joez74's Avatar
joez74
I hear ya. They will be here tomorrow, so I'll have my tire guy look them over. I got them through Summit so I know I have a good return policy.
Old Sep 28, 2009 | 07:49 AM
bashcraft's Avatar
bashcraft
They've been making unilug wheels for 30-40 years, maybe longer. I've used them before and never had a problem and I've never heard of anyone else having problems.
Old Sep 28, 2009 | 08:38 PM
'75's Avatar
'75
I'm just saying , why use them if there is a single pattern wheel available. I've used them before too, but just never felt they were the best choice.
Old Sep 29, 2009 | 07:54 AM
bashcraft's Avatar
bashcraft
Well, if you can do the engineering calcs and prove that it's a flawed design, by all means go ahead and enlighten us. But to tell someone they shouldn't use a certain product because you feel they're unsafe even though they're not is a little rediculous.
This is like all those people saying that the engine lifting plates that bolt to the carb flange on the intake is a disaster waiting to happen. But if they took the time to look up the tensile strength of a 5/16 bolt even if it is screwed into aluminum, they'll find that they're completely safe. By the way, the tensile strength (breaking strength) of a 5/16 course thread grade 5 bolt is 6,300 lbs.
Old Sep 29, 2009 | 08:00 PM
'75's Avatar
'75
joez74, I hope your wheels work good for you, I love the Crager SS.
Bashcraft, I hope you get to feeling better.
Old Sep 29, 2009 | 08:09 PM
Drews69's Avatar
Drews69
My '69 has had a set of ET unilugs on it for about 30+ years without any issues...
Old Sep 30, 2009 | 07:25 AM
bashcraft's Avatar
bashcraft
What can I say, it was Monday.
To C3 Wheel bolt pattern
