Dana 44
Old Sep 24, 2009 | 02:18 PM
delgal's Avatar
delgal
Default Dana 44
hello,
is it possible to put a DANA 44 in a C3 corvette of 76?
Is this a useful option???
To receive an engine 454.500hp
transmission manual
David
Old Sep 24, 2009 | 02:52 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Dana 44s were used on 80-82 Corvettes, so it should be adaptable to an earlier car. Whether it will hold up to 500HP is debatable.
Old Sep 24, 2009 | 03:04 PM
delgal's Avatar
delgal
Default Dana 44
which would be the council???
which differential to choose???
Old Sep 24, 2009 | 03:24 PM
68 NJConv 454's Avatar
68 NJConv 454
A well build stock differential will handle 500hp as long as you don't run slicks and drop the clutch at high RPM. Might have to be careful at the track too.
The Dana 44 could be used but you may need to modify the batwing and adapt your frame to fit it. I don't know much about the batwing setup.
Again, its not bullet proof.
Old Sep 24, 2009 | 08:02 PM
FRSTR90's Avatar
FRSTR90
I've heard that as little as 350 HP and slicks can make them puke..
To Dana 44
