Brake Line Distribution Block / Switch
Old Sep 25, 2009 | 03:50 PM
Burnt71's Avatar
Burnt71
Default Brake Line Distribution Block / Switch
Could someone educate me on how a "brake line distribution block/ switch" works ? The theory on how it works What's inside ? are they repairable / How do you troubleshoot ? Where does the wire go to ? What does the electrical part do ?
Old Sep 25, 2009 | 04:00 PM
...Roger...'s Avatar
...Roger...
Old Sep 25, 2009 | 04:03 PM
...Roger...
The wire goes to the brake light in the dash. Inside the block is a piston that contacts a terminal and turns the light on. I'm 99% sure the block cannot block the flow of fluid.
Old Sep 25, 2009 | 04:08 PM
Burnt71's Avatar
Burnt71
Old Sep 25, 2009 | 04:24 PM
pws69's Avatar
pws69
Each input "side" of the block is connected to the outputs of the Master Cylinder and the block outputs are connected to each "system"(front and rear). There is a "slide" inside that needs to be centered in order for the fluid to flow to each "system" (front and rear) and keep the Brake light switch/lamp off. The switch is off when the "slide" is centered and on when off center. If one of the systems springs a leak, then the pressure from the OTHER system pushes the slide toward the failing side, BLOCKING THE FLUID from going to that side, turning the switch on which causes the Brake light to come on.
Old Sep 25, 2009 | 04:45 PM
Burnt71's Avatar
Burnt71
So if I have my brake light on and there are no leaks it must be this switch ?
Old Sep 25, 2009 | 04:56 PM
...Roger...
Are you sure the valve blocks the flow of fluid ? It makes sense that it should but looking at the cutaway above ,the master cylinder feed line and both lines from the front wheels flow into the area with the spring and I don't see anything to seal the flow of fluid.
Old Sep 25, 2009 | 05:02 PM
'75's Avatar
'75
My 75 has distribution/switch block that operates this way. Proportioning valves typically operate as pws 69 states.
Burnt 71, you can unplug the wire from your switch to see if it is causing the light to come on. The parking brake lever has a switch that operates the same light.
Old Sep 25, 2009 | 05:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
So it doesn't block any fluid from the failed side as some kind of safety device leaving you with the unfailed front or backs to stop you ? It just gives you a warning light as your foot on the brake travels to the floorboards and your Vette hits a parked Brinks truck. Brilliant ! and they wonder why they went bankrupt ?
Old Sep 25, 2009 | 05:29 PM
'75's Avatar
'75
If the front or rear springs a leak, the other should still function although the pedal will be much lower. The systems are split in the mastercylinder.
Old Sep 25, 2009 | 06:04 PM
Duke94's Avatar
Duke94
You are correct, the valve will not block the flow of fluid to the failed side.
Gary
Old Sep 25, 2009 | 07:39 PM
MotorHead's Avatar
MotorHead
I agree but a total failure, one reservoir looses all fluid, I bet you aren't going to be stopping very good and your foot is going to hit the floor boards, could be wrong though. Never happened to me. If you open one bleed nut the system won't work and your foot goes to the floor no ?
To Brake Line Distribution Block / Switch
