79 alluminum wheels
Old Sep 28, 2009 | 01:37 PM
ED79's Avatar
ED79
Default 79 alluminum wheels
Were these wheels originally this dull looking?
I've noticed the early 80's seem to shine like chrome.
Will these Mothers, Blingmasters etc. polishes do anything for this?
"Man I need some shine" Thanks ED
Old Sep 28, 2009 | 02:09 PM
mds3013's Avatar
mds3013
The wheels on my '77 were dull originally. I used sand paper to even out scratches and scotch brite pads to get a uniform finish. Then polished with mothers aluminum polish. You can use a polish pad on a drill motor but be careful around sharp edges as it can dig in and jump around a bit. I like the polished look much better. There are some threads on the forum about others ideas. Good luck, mds...
Old Sep 28, 2009 | 04:05 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
there is nothing magical to polishing aluminum other then lots of hard work and sore fingers......i used all of what everyone else said and 2000 grit wet sand paper and then a buffing wheel.....lots of work the good side is that once youhave the nice shine the maintenance is not as bad as the work to get it there
Old Sep 28, 2009 | 04:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Dull in the sense of not polished. There was also a clear portective coat on some years.
Old Sep 28, 2009 | 04:42 PM
thegazman's Avatar
thegazman
Default thegazman
Buy the mushroom and facer buffing set for your drill from Eastwood along with some of their fine buffing compound. After you get the wheels almost looking like chrome switch to Mothers polishing compound. Mothers polishing ball works well for finishing and is quick when you want to do a little touch after washing.
Old Sep 28, 2009 | 07:30 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The wheels from 77-79 were not clear coated nor were they polished to a high luster. Starting in 1980 GM put clear coating on the higher polished wheels to protect the finish.
I’ve always put clear over the earlier design wheels after polishing them for the same reason. They won’t look factory but they will come to life.
Willcox
Old Sep 29, 2009 | 08:36 AM
ED79's Avatar
ED79
Thanks to all replies, so even if they were somewhat dull per era they can have more of a shine.
I like the clear coat idea also. Wonder how long it lasts?
Old Sep 29, 2009 | 08:03 PM
0Willcox Corvette
Former Vendor
I didn't go in to much detail on this but I used to take an old cloth buffing pad and some compound for a final buff. It will eat you alive but it will make quick work out of putting a polish on the wheels.
How long will the clear stay on will depend on what you use.
Willcox
To 79 alluminum wheels
