Electric fan question
Old Sep 29, 2009 | 08:59 PM
fantic's Avatar
fantic
Default Electric fan question
I installed a electric fan in my 77 and it runs all the time after the temp reaches about 180. I have a 180 thermastat and the fan switch is supposed to turn on at 200 and off at 185. At first I had the sending unit in the head and thought there might be a difference in temp between it and the intake. I moved it to the intake by the thermostat and didn't make much difference. I have since replaced the sending unit with another one. I checked the temp with a mech gauge in the intake and with the dash gauge and they are pretty close. Help please!
Old Sep 29, 2009 | 09:38 PM
72LS1Vette's Avatar
72LS1Vette
The 180 thermostat is mechanical so it might not be 100% accurate. Perhaps it's opening at 185 instead of 180. You could try a 190 degree thermostat to see if it makes a difference. The other possibility is that the temp is not going below 185. Do you have a fan shroud installed and is the radiator sealed in the support? Do you have the lower spoiler lip installed? All of these things can make a difference.
Rick B.
Old Sep 29, 2009 | 10:01 PM
SteveG75's Avatar
SteveG75
I had the same problem with my 195 on/185 off switch and a basic generic 180 thermostat. Switched to a Robert Shaw Hi-flow 180 stat and problem solved.
Only issue that I have now is that I had to replace my temp sender and it is accurate at 200 but shows 160 vice 180. It was at 180 with the old sender so I know the stat is good and just live with it.
To Electric fan question
