door skin help
Old Sep 29, 2009 | 09:54 PM
killer454's Avatar
killer454
Default door skin help
started rebuilding my 1980 doors today and completly dissasembled the drivers door for rebuilding.
got about half way through dissasembly and noticed about a gallon of body filler in the door.
how hard is it to change a door skin on this 1980 vett?
the cheepest door skin i have found is corvette central and it is still 339.00 bucks for each door skin.
can anybody give me the process of getting the door skin off and new one on?
any advice on this would be very helpfull to me right now
thanks for the help guys
Old Sep 29, 2009 | 11:09 PM
wombvette's Avatar
wombvette
Very simple actually. It is just glued onto the framework. So, separate with a putty knife or blade of some kind and remove the skin. Bond the new one to the frame.
Old Sep 29, 2009 | 11:12 PM
SIXFOOTER's Avatar
SIXFOOTER
Use a heat gun to heat the metal side, then a Sharp, Thin putty knife to cut the glue around the perimiter of the door.
Old Sep 30, 2009 | 02:17 PM
killer454's Avatar
killer454
ok thanks for the help got the door skin off the door last night and have the door frame cleanedup.
i guess it wont hurt to go ahead and rebuild this door with the panel off will it?
i have new regulator,door latch,door handels,and window track rebuild kit,to put in it.
Old Sep 30, 2009 | 02:39 PM
wombvette's Avatar
wombvette
Sounds like a plan.
Old Sep 30, 2009 | 06:11 PM
killer454's Avatar
killer454
well just ordered a complete door from a salvage yard in st charles for 647.00 dallars.
that should take care of my problem with my door
now im going to have an extra door latch ***,and 2 window regulators.
thanks for the help everybody but in the long run that door was not worth messing with to me.
thankyou
Old Oct 1, 2009 | 01:11 AM
gingerbreadman1977's Avatar
gingerbreadman1977
killer did you take any pictures of pulling the door skin off. i would love to see that. did you get it off in one piece without it breaking?
Old Oct 1, 2009 | 01:30 AM
killer454's Avatar
killer454
i went ahead and bought a used door complete from a salvage yard because my door frame was also missing the spot welded brackets for the arm rest.
my door skin was junk anyway so i took a heat gun and got as much as i could with that it worked pretty good till i got to the area where the outside mirror bolted to the door they glued it onto a bracket inside the door at this point.did not find that out until i cut the panel with my die-grinder.
i found a whole complete door with everything in it for 647.00 this seemed to be the best way for me to go on this with the new door skin costing me 339.00 and the window i had had a chip in it to and then the stipped out holes and no bracket for my armrest to bolt to just seemed better to buy a used door.
To door skin help
