Your thoughts?
Old Oct 1, 2009 | 09:36 PM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by Project80
Was the engine turning at normal cranking speed when you did the compression test?
Yes. About 5 rotations at regular speed
Old Oct 1, 2009 | 10:47 PM
GDaina's Avatar
GDaina
time for a tear down
Old Oct 1, 2009 | 11:29 PM
Jclgodale3's Avatar
Jclgodale3
yeah...mise well. Just got the car and drove it straight to the garage. Not even a test drive. Block appears to be out of a 65 vette so maybe I should preserve it and start new?
Old Oct 2, 2009 | 12:16 AM
GDaina's Avatar
GDaina
what did you get?
Old Oct 2, 2009 | 12:24 AM
Jclgodale3's Avatar
Jclgodale3
what did you get?
68 vert...non original motor
Old Oct 2, 2009 | 11:15 AM
GDaina's Avatar
GDaina
at least displacement is correct...if it's a 65 block, may be worth some $$$$$ to NCRS type...
Old Oct 2, 2009 | 12:35 PM
Jclgodale3's Avatar
Jclgodale3
Here's the block numbers:
Block is GM 3782870 Pad is FI03IS
Old Oct 2, 2009 | 01:17 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Just checking about the compression test, you mentioned that it was turning over slowly on the first turn. Was the engine turning at normal cranking speed when you did the compression test?
All your numbers are low and your two way out of line cylinders are on different sides of the engine, so when you did this check did you have the carb butterflies wide open? If not you could get goofy numbers like you have.
Old Oct 2, 2009 | 02:37 PM
GDaina's Avatar
GDaina
I'm thinking if the butterflies are open the numbers could be even lower?
Old Oct 2, 2009 | 02:58 PM
Manuel Azevedo
Not really. You are allowing the full air charge in with them open for the highest reading and one that is the most consistane also. Close them and you do not fill the cylinder completely.
Old Oct 3, 2009 | 12:27 AM
Jclgodale3's Avatar
Jclgodale3
Well hell...got tired of troubleshooting so I just...
Old Oct 3, 2009 | 12:45 AM
GDaina's Avatar
GDaina
eweeeee that is nasty looking...
Block 1965 passenger 250, 300 horse
1965 Chevelle 250, 300 horse
1965 Vette 250, 300, 365, 375 horse
2 bolt main N on main bearig caps indicates nodular crank lack of N indicates forged crank
flint 10th month IS for suffix, cant find it only one that's listed is for a passenger 427 385 horse
Old Oct 3, 2009 | 01:31 AM
  #33
Jclgodale3's Avatar
Jclgodale3
and thanks for the decode. Suppose the short block would be worth anything to someone with a 65?
Old Oct 3, 2009 | 02:09 AM
  #34
Goody's Avatar
Goody
No wonder it is tired.....Fram filter.
Old Oct 3, 2009 | 02:58 AM
  #35
73StreetRace's Avatar
73StreetRace
But it seems that the oil filter is the only part which looks good !
Old Oct 3, 2009 | 07:49 AM
  #36
Jclgodale3's Avatar
Jclgodale3
And to think there was a brand new set of Jet Hot Hooker Sidepipes bolted to it!
Old Oct 3, 2009 | 08:51 AM
  #37
mikep3's Avatar
mikep3
Goody, I have been using a Fram TG5 because it is longer than the specified TG30 and has an anti-drain-back valve.
What filter name & number would you use if the Fram is not up to par?
To Your thoughts?
Old Oct 4, 2009 | 01:05 AM
  #38
Jclgodale3's Avatar
Jclgodale3
Well...tore the motor completely down tonight. I truly can not believe this pos motor was still running. Someone had no clue pics to follow
Old Oct 4, 2009 | 03:38 AM
  #39
73StreetRace
Just a question : how many miles on this engine, if you know ?
Old Oct 4, 2009 | 12:34 PM
  #40
Jclgodale3's Avatar
Jclgodale3
no clue. It has been rebuilt though at some point. Noticed someone used a punch to number rod caps.
