Your thoughts?
Old Oct 4, 2009 | 07:20 PM
  #41
Jclgodale3's Avatar
Jclgodale3
ok...suppose this could be a few of the problems?
This rod bearing had to be close to "spinning"
Check out the heat spots from the friction
And the #3 piston
Old Oct 4, 2009 | 08:26 PM
  #42
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Rebuild it again.
FYI those older blocks (pre '70) had plenty of meat in them. U can still buy 0.080" overbore pistons sitting on the shelves. Something else is that i recently learned is that there are millions of used 350" s (3.48" stroke) with the small journals that will fit into that small journal block of yours - forged s BTW. That would give u more cubes for a little pocket change.
Just my 2 cents but there are so few engines that u can build so cheaply and make 400hp maybe even 450hp. Heck u already have the block and heads possibly reusable rods and too. With all the mega $$ blow outs using forged parts and fancy alum heads on this forum I would really enjoy reading a success story on a budget build here.
Good luck and keep us posted with your progress. U did such a great job restoring your vette i have high expectations on your engine replace/rebuild.
cardo0
Old Oct 4, 2009 | 10:35 PM
  #43
GDaina's Avatar
GDaina
resizing the rods is a must and cheap in comparison to buying new ones..and by the picture of number 3 piston, it's a miracle you had compression at all....
Old Oct 4, 2009 | 11:23 PM
  #44
Jclgodale3's Avatar
Jclgodale3
yeah...would explain the extremely low reading
Old Oct 5, 2009 | 01:33 AM
  #45
73StreetRace's Avatar
73StreetRace
Yeah, this engine needs love, but I'm sure you will give it some.
You didn't tell us about the cylinder walls, especially those with the broken rings ?
However that may be, good luck with your rebuild and keep us informed...
Old Oct 5, 2009 | 08:08 AM
  #46
Jclgodale3's Avatar
Jclgodale3
All 8 cylinders had the upper compression ring shattered. The cylinder walls are actually not as bad as I would expect given the broken ring issues. I will have to see if they can be cleaned up. I believe the block is already .20 over bore
Old Oct 5, 2009 | 08:11 AM
  #47
GDaina's Avatar
GDaina
I bet they were busted upon installation
Old Oct 5, 2009 | 08:55 AM
  #48
73StreetRace
It wouldn't surprise me ! Broken rings on all cylinders means something was badly made from the beginning !
Old Oct 5, 2009 | 08:13 PM
  #49
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
What a fine mess you got yourself into lol.
Old Oct 5, 2009 | 08:47 PM
  #50
Jclgodale3's Avatar
Jclgodale3
Yup. My thoughts exactly as #5,6,7 and 8 came out
Old Oct 5, 2009 | 08:48 PM
  #51
Jclgodale3's Avatar
Jclgodale3
You know me...if it's not one mess, it's another
Old Oct 6, 2009 | 12:12 AM
  #52
SHAKERATTLEROLL
Yep I sure do lol. And I knew you were looking for a new can of worms lol.
But do not worry I am sure you will work them all out in time.
Old Oct 6, 2009 | 01:46 AM
  #53
73StreetRace
I just hope he didn't open Pandora's box...
Old Oct 6, 2009 | 07:15 PM
  #54
Jclgodale3's Avatar
Jclgodale3
