Carborator
Old Oct 4, 2009 | 11:05 AM
TOR's Avatar
TOR
Cruising
Default Carborator
Hi
I have a 1969, 427 with a Edelbrock torker II 2-0 intake manifold.
I have tried with a Holley carburator 4779 750 DP. ( double pump )It was a little to "violent ". Not easy to start and used a lot of fuel.
Do you have any proposal. Holley or Edelbrock, and what type.
Mostly street, but I like to drive fast.
Old Oct 4, 2009 | 11:47 AM
Vesa's Avatar
Vesa
Try vacuum holley
http://www.holley.com/types/Street%2...raditional.asp
or vacuum demon
http://www.barrygrant.com/demon/default.aspx
750cfm might be good for you...
Old Oct 4, 2009 | 04:53 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Save your money and tune the 750Holley, no reason a properly working carb would make a motor hard to start and if tuned with a wideband O2 you can get good mileage from the carb
Only reason I would change carbs if it is a 20 year old gummed up pos
Old Oct 4, 2009 | 05:24 PM
Fishndude's Avatar
Fishndude
I'll tell you what, those new vacuum secondary Summit carbs are pretty darn nice for the price.. I bought a BG Mighty Demon 750DP and paid over $600 for it and there was no performance gain over the 750 Summit carb.. To be honest, the off idle response was just as good as the BG and it pulled hard when I needed it.. I purchased the BG in hopes of a performance gain but there wasnt any.. The Summit carbs are under $275 NEW and I can promise you any performance street car I own in the future will be wearing one.
Old Oct 4, 2009 | 06:00 PM
baxsom's Avatar
baxsom
auto or manual trans.
auto trans will normally respond better to vacuum secondaries.
that torker manifold is supposedly not the best in the world either.
granted there arent many square bore manifolds that will fit under a stock BB hood but even the rectangular port LS6 intake will,so i have heard, perform better than the torker.
i use the annular booster 750 speed demon on the ls6 intake on my new 430hp/500lb/ft crate 454. it all fits under the stock hood and if i am leaving any hp behind it aint much. whats nice is the demon was taken from box to motor, out a half a turn on the idle screws and a few jets up all around and i couldnt be happier.
Old Oct 5, 2009 | 01:19 PM
TOR's Avatar
TOR
Cruising
Thanks for the answers.
I have auto trans.
My torker intake is new. I got a Edelbrock carb 1407 from a friend. I will try it first and think about what to do.
Old Oct 6, 2009 | 08:06 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Originally Posted by TOR
Hi
I have auto trans.
Whatever you put on your Vette, you'll have to spend time tuning it; set floats, jets, idle, etc.
Just today I spent the better part of the day doing the very same thing I mentioned. Now I'm getting "miles per gallon" instead of "gallons per mile".
To Carborator
