350 to 327 engine swap
Old Sep 30, 2009 | 12:42 PM
jdacpa's Avatar
jdacpa
Navigator
Default 350 to 327 engine swap
Does anyone know if I can replace the 350 in my 81 vette with a 327?
Jeff
Old Sep 30, 2009 | 01:14 PM
Grumpy 427's Avatar
Grumpy 427
Yes its a direct bolt in. Why would you want to go for smaller cubes less torque etc. The 327 will hve to work harder to get that car moving?
Old Sep 30, 2009 | 01:18 PM
Solid LT1's Avatar
Solid LT1
Your main concern will be if the 327 has cylinder heads with threaded holes to allow the later accessories to attach to the motor. Most 327 motors are pre-1969 vintage and didn't have accessory holes in cylinder heads, but maybe someone swapped the heads out for you to a later style.
Old Sep 30, 2009 | 05:30 PM
Iroc57's Avatar
Iroc57
X2 on the accessory mounting
Old Sep 30, 2009 | 06:22 PM
GDaina's Avatar
GDaina
why not use the 350 heads on the 327 block?
Old Sep 30, 2009 | 08:23 PM
markids77's Avatar
markids77
"There's no substitute for cubic inches" is a true statement from a performance standpoint. Unless you have a free 327 in perfect running condition floating loose in the garage, spending the same dollars you will have in the 327 on the 350 should net greater gains in performance. May we ask why you are considering this swap?
Old Sep 30, 2009 | 10:35 PM
Iroc57's Avatar
Iroc57
There is one train of thought here...
You can twist a 327 pretty high which means that you could run silly gears without running out of motor. A friend back in the day did this with a Nova. He built a 302 and ran 5:13s...the car was snappy to say the least.
Old Sep 30, 2009 | 10:45 PM
CCrane65's Avatar
CCrane65
That's the same thing Chevy did with the Z/28 in 1969. They put a 283 crank in a 327 and got a 302 for Trans Am racing.
The 350 based LT-1 replaced the 302 for Trans Am racing and it wound just as high but had more torque for twisting those rear gears.
It's up to you but I know which way I'd go.
cc
Old Oct 1, 2009 | 01:40 AM
Solid LT1's Avatar
Solid LT1
This was a pretty interesting article in last months Super Chevy, I tend to agree but think the 302 had a little advantage with they way they built it. The saying in my old days as a street racer was ALWAYS race a 302 Z/28 from a standing start NEVER from a rolling start not even a 5MPH roll! Link to motor article: http://www.superchevy.com/technical/...ing/index.html
Old Oct 1, 2009 | 07:43 AM
1982CorvetteDude's Avatar
1982CorvetteDude
I always heard the 327 was a pretty bad **** engine compared to the 350. I'm most likely wrong though. My cousin swore by them though.
Or maybe it was just the 327 heads he liked.....
Old Oct 1, 2009 | 07:53 AM
L88Plus's Avatar
L88Plus
You're going the wrong way. Stroke the 350 block to 383 instead of destroking it. 327's were the shnizzle in their day, but you didn't see many of 'em made after the 350 came out. Reckon there's a reason???
Old Oct 1, 2009 | 02:44 PM
jhuff's Avatar
jhuff
Right. All things being equal "there's no replacement for displacement"
Old Oct 1, 2009 | 03:28 PM
mysixtynine's Avatar
mysixtynine
I am not sure but I believe the older heads may not accommodate the newer exhaust manifolds. I seem to remember the bolt patterns changed in the mid 70's not to mention some stuff might be metric in the 81. Not sure though. That may have been the 305's or 307's.
Old Oct 1, 2009 | 03:31 PM
DZRick's Avatar
DZRick
That is an interesting article, I'm sure most won't read it though because they don't want to believe it.
HORSEPOWER NUMBERS
RPM 302 327 350 350 ('71)
3000 167 196 208 199
3300 184 210 232 223
3500 206 232 254 246
3800 233 261 283 275
4000 248 275 298 291
4300 272 297 318 311
4500 283 308 329 324
4800 301 324 341 340
5000 311 333 347 347
5300 326 344 352 355
5500 333 349 353 361
5800 347 347 350 362
6000 350 348 348 361
6300 353 352 348 353
6500 356 347 342 345
6800 356 339 329 332
7000 352 331 312 319
TORQUE NUMBERS
3000 292 332 364 349
3300 293 334 369 354
3500 309 348 381 369
3800 322 360 391 379
4000 325 362 391 382
4300 332 363 389 380
4500 331 360 383 378
4800 329 355 373 372
5000 327 350 364 364
5300 323 341 349 352
5500 318 333 337 345
5800 314 314 317 328
6000 307 305 305 316
6300 295 293 290 295
6500 287 281 277 279
6800 275 262 254 257
7000 264 248 234 239
Old Oct 1, 2009 | 04:08 PM
markdtn's Avatar
markdtn
Where is DJ Dep? Mr. Chevy 302
Old Oct 1, 2009 | 05:27 PM
GDaina's Avatar
GDaina
There really isn't that much difference in HP between the motors, although the LT1 has more than the others, which was to be expected, but all in all, pretty even.
Old Oct 1, 2009 | 07:44 PM
Solid LT1's Avatar
Solid LT1
DJ has NOTHING on me, I have owned over five 68/69 302 Z/28 Camaros and six 70/72 LT-1 Vettes. Presently I own 2 LT-1 Vettes (OK I guess one is claimed by my wife but, I'm the one maintaining it.) 302s are OK but when push comes to shove, I'll take a LT-1 anytime!
To 350 to 327 engine swap
Old Oct 1, 2009 | 09:04 PM
markids77's Avatar
markids77
Nirvana might just be found in a full Nascar spec SB2 from Hendrick or Childress. Never saw a dyno chart on a 9600 RPM unrestricted Cup engine but hear the 700 HP figure regularly enough to at least think it might be so. They live long enough to make 3 or 4 seasons in many of our street cars... we tend to be a low per year mileage group. Both organisations sell "customer" engines... wonder what the buy in requirement is?
Old Oct 1, 2009 | 09:27 PM
Goody's Avatar
Goody
Jeff
Depends.....Legally for smog inspection states then NO you can't because that engine was not offered in the model year vette and it is older. Now you could put in a new LS7.
But if you want to know will it just bolt in just like the other one size wise? Yes it will. Externally it is the same engine.....the heads may cause you issues as already stated so look for the accy holes.
I agree with the others though...No replacement for cubic displacement. There is a reason all racing organizations limit the CID of an engine for a class.
Old Oct 1, 2009 | 09:30 PM
midyearvette's Avatar
midyearvette
i read that article before and it clearly shows the limitations of the 202 heads ....that's why the 302 has such respectable hp numbers with the shorter stroke and actually breathes better than the 327 or 350 with the same heads...they were great heads back in the day but if they tested with some after market brands you would see the larger displacement mills skewed to higher hp numbers, intrestingly enough are the torque numbers ...proving again and again there is no substitute for displacement on a normally asperated engine...good stuff, thanks for the link....
