I have searched but I have not found A good tread on trouble shooting or testing my A/C system. I know I have all of the elc. system working, but the vacuum system and the rest of the A/C system I know nothing about. I have also swaped my v belts for a 1995 serpentine belt system so I guess I will have to have some hoses made . Advice on this would also be very helpful
If you do not own a copy of the Chevrolet Chassis Service Manual, I highly recommend that you get one. Under the section on Air Conditioning, it has individual drawings/diagrams of [both] the vacuum system and the electrical system. The standard wiring diagram does not show this system in it. Read the material in this section of the manual to understand how it works. Also, study the vacuum diagram and how it interconnects with the [mechanical] control head in the shift console. Basically, some electrical contacts on the control head turn the system ON and OFF, depending on which setting you have selected. The [electrical] blower system selects the blower speed required, and the vacuum system merely selects the appropriate position for (vacuum operated) diverter doors in the plenum housing so that the airflow comes from the desired source (inside air or outside air) and the discharge air comes from the correct vents. That's about all there is to it. But you really need that manual to understand it and trace down your problems.
GM is known for excellent A/C systems & it's very reliable. Aftermarket are recir.only.
The vac. control system is actually very reliable.
1) The vac. line from engine can be damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix.
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease to fix.
3) If you have a heater, the small vac. tube to heater hose valve underhood probably also needs replacing. Block w/o heater.
An A/C shop can make hoses or you can do it. Are you changing to R134?
I have a different compressor that uses less hp & I made up hoses to stock A/C system.
Works great.
I have found a vacuum diagram and it seems that my control head, dosn't work along with all but one of my vacuum solenoids. I am wondering if there is any way to test my evaporator? To top it all off I don't think there is a piece of the whole assembly that is not broke ( nothing a little bit of fiberglass won't help I guess?) but I did replace my heater core and shut off valve about 2 years ago and now I see why I can't get heat to stop coming threw the vents. Due to the fact the whole assembly is not sealed to the fire wall. All in all I think it will still be a little cheaper to replace with aftermarket stock parts.Once I can track down the parts, I just want to spend my money in the right place.
Anyway once the HVAC is done I will have totally purged my car of all the past owner's screw ups..............I hope
To test the evaporator all you have to do is make sure it doesn't leak, so put a vacuum or pressure in it & see if it holds.
You should try pressing the control switch together & try the A/C vac. system.
You can do that if you have isolated the Evaporator , but if the Evaporator is still hooked up to the rest of the system....it wont help. To check just the Evaporator for leaks while it is in the system, pressurize the system to at least 60 psi using Refrigerant then using an electronic leak detector after setting it at a slow steady 'click' .... insert its Wand/Sensor thru the closest air vent and carefully push it in as far as the wand probe will go without forcing it,,, leaving it there for awhile. Using the same method, push the probe into the return air passage if it is accessible as far as it will go from within the cab down near the floor on the passenger side . If the clicking sound of the Electronic Leak Detector increases , then you have an Evaporator leak. If not, then you dont.
The most likely source of leaks on an old Vettes A/C system, is at the O-rings in each Connector found in the Suction, Liquid, and Hot Gas lines . Other popular places are the compressor shaft seal and the Condensor where a small stone from the road damaged a Tube. Use the Electronic Leak Detector for these areas as well .
Once you fix the mechanical issues, my advice would be to contact a local Corvette Club to recommend a good A/C repair person. They can test your system, evacuate it, and recharge it in short order. The R12 is rather expensive (compared to the 'new stuff'), but that's easier than replacing half of your existing system. Now, if you find that there are major problems with the system anyway, it's time to convert to the new refrigerant. Have you depressed one of the Schrader valves to see if there is still pressure in the system?
there is no valves or lines left. The only thing I have that was left under the hood that had anything to do with the a/c system is the dryer and it was covered in 30 years of dirt no telling how long with out hoses. Which reminds me to ask if the dryer needs to be replaced ? or if there is a way to check it
If the dryer has been open to the air for any period of time then the dessicant inside is saturated and needs to be either dried out or replaced. I have never serviced one but given the age I would likely just replace it.
