park brake pad install, need help
Old Sep 30, 2009 | 04:57 PM
rgpta's Avatar
rgpta
Default park brake pad install, need help
I know there are plenty of threads relating to this, but I was wondering if someone has pictures as to how the parts align. I read the corvette mag tech articlle but doesnt show how the cable holder goes in or whether the adjusters go behid the back plate.
Any help appreciated,
Also if i wanted to replace the brake backing shields, how do I remove? Not sure if I have to unbolt the drive diff or ?
Old Sep 30, 2009 | 06:21 PM
Duke94's Avatar
Duke94
This help you at all?
Gary
Old Sep 30, 2009 | 06:22 PM
spedaleden's Avatar
spedaleden
Read this
http://forums.corvetteforum.com/c3-t...rake-help.html
Rear backing plates are not that easy, most due them when you do rear wheel bearings.
Old Sep 30, 2009 | 09:21 PM
rgpta's Avatar
rgpta
Thanks Picture helps
Old Sep 30, 2009 | 09:34 PM
rgpta's Avatar
rgpta
how does the e lever get installed. I see one part holds down the the cable but not sure which way the lever should be placed
To park brake pad install, need help
