Heater problem
Old Oct 1, 2009 | 03:57 PM
G Littman's Avatar
G Littman
Default Heater problem
I inherited an 81' Vette that I'm rebuilding and have discovered the heater blows fine (no pun) with NO HEAT. There's a new thermostat and the engine's just been totally gone over and worked on. What would cause a perfectly warmed up engine and working thermostat, to not blow hot air?
Thank you.
G
Old Oct 1, 2009 | 04:05 PM
jimmyshine's Avatar
jimmyshine
probably a bad shut off valve (if it's still in place).
check valve if totally open, then check vacuum on that valve.
Old Oct 1, 2009 | 04:09 PM
spedaleden's Avatar
spedaleden
1 st check for a valve on one of the heater hoses. There maybe a shut off valve installed to keep the cooler in the summer.
2nd check The factory installs a valve on the heater hose. This valve has a vacuum line attached to it. You need to make sure it working properly.
3rd check temp cable from heater control. Make sure it is moving the door properly.
To Heater problem
