Had shop do tune up at beginning of '09 season and take care of the mysterious brake light that keeps coming on (red)...so the reputable shop blead the brakes, it's six months later adn about 2000 miles and the brake light is coming on again, what else could this be, mostly comes on under hard stopping conditions...
You may have a 'run-out' problem with the rear rotors, if the master cylinder is full but the light comes on when you apply the brakes then bleed the brakes and see if the problem reoccurs. If the problem comes back then check the run-out on the rear rotors.
Forgive me in advance, but what is "run-out" I am not familar with that term.....I have been getting a squeek for years when I am not applying the brakes, sounds like coming from the rear, so I think you might have hit the nail on the head...
Runout is the distance the rotor "wobbles" as it rotates. To measure runout you mount a dial caliper and set the pickup on the rotor, then spin the rotor. If the rotor wobbles more than .006 inches you need to have it machined on the car to eliminate the runout. Excessive runout can lead to reverse oscillation (air pulled into the system through the piston seals), poor pedal pressure, and the brake light coming on.
That sounds like what it might be...will need my technician to check it out soon as the wifeeeeee gets a lil' nervous when we take an off-ramp at 60-65 and the brake light comes on as I tap the brakes before I hit the apex :-)
KO
KO
If your tech doesn't find enough runout to cause the problem have him check the dynamic balance of the tires. I've seen this coupled with sleeve bores on the high side give this problem.
Is this a pretty hard problem to pin down overall?
Thanks,
KO
Thanks,
KO
Shouldn't be if the tech knows already what he's looking for. Getting an accurate measure of the runout can be a challenge especially if the axle has more end play than allowable rotor runout.
Either rotor runout or loose bearings can cause you to lose your brakes and wifeeeeeeeeeeeeeeeeeeeeeeeeeeee will be really upset then.
