327 to 355 problem
Old Oct 3, 2009 | 08:36 PM
Cuervos77's Avatar
Cuervos77
Default 327 to 355 problem
Okay i was reacently given a 355 it was a 327 that was made into a 355 the engine is pretty built i wanna put it in my 76 but the only problem is that it doesnt have power stearing is there a way to put power stearing in this engine or no it came off of a 60s corvette?
Old Oct 3, 2009 | 09:04 PM
markids77's Avatar
markids77
Are the heads deilled for accessory mounts... like what's in your car now? Is yes, just swap your stuff in. If no, then your 355 heads are early GM cast iron parts and might be worth enough as restoration bits to finance a good chunk of some better parts. BTW, I would never install an engine I did not help build without at least partial disassembly to see if it was put together correctly. Engine swaps are enough work that a gasket set and a weekend's work could be a wise investment.
Old Oct 3, 2009 | 09:33 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Power steering doesn't bolt to the heads; it bolts to the block. Both blocks have the necessary mounting holes for PS.
Old Oct 3, 2009 | 09:43 PM
Cuervos77's Avatar
Cuervos77
well the guy told me it has camel back heads or something like that he just told me he built the engine up pretty good thats why im swaping it in its a brand new engine about a month old
Old Oct 3, 2009 | 09:48 PM
Cuervos77's Avatar
Cuervos77
Also he said its a older block from a 67 he said it doesnt have holes for power stearing he said its all flat in the front?
Old Oct 4, 2009 | 01:10 AM
TimAT's Avatar
TimAT
GM started putting the lower mount holes on SB's in 1955. I can't recall ever seeing a Gen 1 SB without them. 4 holes, 3/8-USS thread. 2 on each side of the timing cover. Prior to 69, GM did not have any holes in the heads for accessory mounts.
Trivia tidbit- those lower holes in the SB were for engine mounts. They fall in the same location as the front mount on a Ford Flathead. The guy that worked for Ford and was part of the design team that did that had a funny name. Zora-Arkus Duntov.
Old Oct 4, 2009 | 08:58 AM
Ganey's Avatar
Ganey
Originally Posted by TimAT
Trivia tidbit- those lower holes in the SB were for engine mounts. ...
Yes PS should bolt up.
Old Oct 4, 2009 | 12:38 PM
Jclgodale3's Avatar
Jclgodale3
I have a 65 GM block and it had power steering bolted to it
Old Oct 4, 2009 | 02:18 PM
Sundevil64's Avatar
Sundevil64
I think you mean "camel hump" heads, unless you are refering to the small mountain in Scottsdale,AZ.
You should be able to add PS w/o an issue regardless of the heads on the engine.
Old Oct 4, 2009 | 03:01 PM
WTFizzit's Avatar
WTFizzit
The question that immediately comes to my mind is that if the guy that "built" the engine can't determine whether or not a bracket will bolt to the block, is he really up to building an engine worth having?
Old Oct 4, 2009 | 03:05 PM
Cuervos77's Avatar
Cuervos77
well the engine was already built and hes giving it to me it was his fathers and hes not with us anymore and he said he doesnt have a use for it but i cant seem to find any holes where the power stearing should bolt on it looks completley flat there isnt the 4 holes?
Old Oct 4, 2009 | 03:52 PM
WTFizzit's Avatar
WTFizzit
Update------Just went out to the garage and did some checking------I have a SB400 on a stand, the lower driver side holes (the ones that the p/s bracket is mounted to on my '73 350) were never drilled. Also have a 350 out of a '72 pickup (long water pump) that the p/s bracket is mounted to the water pump and the driver side exhaust manifold only. I guess it is possible to have a 327 block with no provisions for mounting the short water pump p/s bracket, anyone want to comment? I suppose to mount the Corvette p/s bracket you would have to drill and tap the block for the correct size bolts if you are hellbent on installing this engine into your '76. I tend to agree with Markids77's advice, considering the effort it takes for the average guy to do an engine swap, I would have to be pretty damn sure of the engine's quality.
Old Oct 5, 2009 | 02:56 AM
TimAT's Avatar
TimAT
If the bosses for the holes are there but not drilled, cast iron drills and taps very easily. 1 hour job unless it's in the car.
Old Oct 5, 2009 | 04:54 AM
c31980's Avatar
c31980
had the same issue with the heads ,, cant mount the alt. no acc holes i tryed to fabricate
something but does not worth it ,,, swetched to edelbrock performer rpm heads ,, that solved this issue
Old Oct 5, 2009 | 02:50 PM
Cuervos77's Avatar
Cuervos77
so camalback heads arent that good is there better ? sould i invest in some better heads?
To 327 to 355 problem
