What does "LS" in Chevy's engine stand for?
Old Sep 30, 2020 | 06:57 AM
Pb82 Ronin's Avatar
Pb82 Ronin
LS = Less sucky (Than previous engines of course)
Old Sep 30, 2020 | 10:57 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Lotsa tire Smoke!
Old Oct 1, 2020 | 12:08 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
Originally Posted by 7T1vette
Your "L" is still an assumption on your part. Could be right....could be wrong. Why discuss or argue the hypothetical when the "General" designated it and knows why it was so identified?
True, could be right or wrong...
However, jumping to the notion that the L represents a real word must then also be applied to the C-group options, M-group options, P-group options, U-group options, etc. Does that mean the L in LS-series engines means something different than the L in LF, LM, and LT engines? (We think of the LT1 as a performance engine so the L & T must mean something cool. The LT4 must have been a real beast... nope, 400cu inch, 180hp (yawn).) By my searches, the L-engine code is used across all Chevrolet models - all. Every Vega, C/K truck, Monte Carlo, Camaro, and even Greenbriar Corvair van used L-coding to identify their RPO engines. Why would Chevrolet use such a wide-ranging system if the L in LS actually represents a real word?
But, like you said, could be right, could be wrong... though mostly right.
Old Oct 1, 2020 | 02:28 PM
71chimera's Avatar
71chimera
how about the "L" in an rpo L31 sbc 350 motor ? it was installed only in trucks; standard workhorse from ~ 96-2002.
and the "L" in L48 or L82 or L36 or LG4 or L69
but then there was also LSMFT; so I suppose LS is as good a guessing game as any
Old Oct 2, 2020 | 12:30 AM
sassc3's Avatar
sassc3
http://www.superchevy.com/how-to/090...engine-history
Old Oct 2, 2020 | 02:25 AM
vette8121's Avatar
vette8121
Originally Posted by 71chimera
Lotsa Spunk
good one
Old Oct 2, 2020 | 08:36 PM
barkingrats
That article only talks about the 1990s and later engines and doesn't really apply to the C2 & C3 engine coding scheme. GM recycled the older nomenclature into these "modern" versions. Titling and subtitling the article with the words history and heritage and then not even mentioning the '60s and '70s engines or the blocks that were the true Gen III and IV engines is pretty short sighted.
Thanks for posting it anyway.
Old Oct 4, 2020 | 12:29 PM
Little Mouse's Avatar
Little Mouse
Loose **** = hooker engine.
Old Oct 4, 2020 | 12:38 PM
Big2Bird's Avatar
Big2Bird
Larry Shinoda
I haven't a clue, nor does it really matter.
Old May 6, 2021 | 07:02 PM
Richg67's Avatar
Richg67
1st Gear
LS was Luxury Sport and LT was Luxury Touring.
LS used to be the high-end (except SS) model back in the '80s with the CL (Custom Luxury) package.
Now can we put this to bed already??
Old May 6, 2021 | 07:44 PM
lars's Avatar
lars
That's absolutely not true. You're talking about vehicle model "cab level" designators, which has nothing whatsoever to do with engine code designators.
This thread is about engine RPO codes. Every engine, and every option, installed on a GM vehicle has an "RPO" code (regular production option.") RPO codes are randomly generated, with certain options (such as engines) falling in certain alpha character groupings. Most engine RPO codes fall in the "L" category, and they simply pull the next available alpha/numberic designator for the next engine without any regard for what the letters "mean." They don't mean anything. Here is a partial listing of some GM engine RPO codes - they simply randomly go down a list, just like the DMV issuing license plates. To think that "LS" means something would be like thinking that DMV license plate numbers have some meaning. If "LS" means something, than I guess LG, LH, and LM must mean something, too... What does the "BF" in RPO BF2 deluxe carpets stand for..? The RPO codes don't stand for anything, and mean nothing - they are randomly generated alph/numeric codes for equipment configuration only. Every year they change - the current Chevy V8 engines happen to be grouped in the "LS" alpha grouping, which is not reflected in this older list shown below as an example.
RPO FY LY DIVISIONAL RPO DESCRIPTION
LA5 84 86 ENGINE, 1.8L L4 (1.8i)
LA7 85 85 ENGINE, 1.5L L4 DIESEL (1.5-5)
LB1 85 86 ENGINE, 4.3L V6 (4.3N)
LB4 85 86 ENGINE, 4.3L V6 (4.3Z)
LB6 85 86 ENGINE, 2.8L V6(HI OUTPUT) (2.8W)
LB8 85 86 ENGINE, 2.8L V6 (2.8S)
LB9 85 86 ENGINE, 5.0L V8 (5.0F)
LC1 82 84 ENGINE, 2.8L V6 (HI OUTPUT) (2.8-1)
LC2 86 86 ENGINE, 3.8L V6 TURBO (3.8-7)
LC3 82 82 ENGINE, 229 C.I.D. V6 (229K)
LC3 83 84 ENGINE, 229 C.I.D. V6 (229-9)
LC4 80 85 ENGINE, 4.1L V6 (4.1-4)
LC5 78 78 ENGINE, 231 C.I.D. V6 (231G)
LC5 85 85 ENGINE, 1.5L L4 (1.5K)
LC5 86 86 ENGINE, 1.5L L4 (1.5-7)
LC6 78 79 ENGINE, 231 C.I.D. V6 (231-2)
LC8 78 82 ENGINE, 231 C.I.D. V6 (231-3)
LC8 83 83 ENGINE, 231 C.I.D. V6 (231-8)
LC9 78 79 ENGINE, 196 C.I.D. V6 (196)
LC9 86 86 ENGINE, 1.6L L4 (1.6-4)
LD4 78 78 ENGINE, 250 C.I.D. STAN 6 CYL (250) LD5 76 86 ENGINE, 231 C.I.O. V6 (231A) LD7 77 77 ENGINE, 231 C.I.D. V6 (231C) LE2 80 86 ENGINE, 2.8L V6 (2.8X) LE3 79 84 ENGINE, 250 C.I.D. L6 (2500)
LE4 80 80 ENGINE, 400 C.I.D. V8 (400X)
LE8 80 86 ENGINE, 454 C.I.D. V8 (454W)
LE9 82 86 ENGINE, 305 C.I.D. V8 (305H)
LF3 82 86 ENGINE, 305 C.I.D. V8 (305F)
LF4 77 80 ENGINE, 400 C.I.D. V8 (400R)
LF5 79 82 ENGINE, 350 C.I.D. V8 (350P)
LF5 83 83 ENGINE, 350 C.I.D. V8 W/SEO(LF5)
LF7 79 79 ENGINE, 260 C.I.D. DIESEL V8 (260P)
LF8 77 79 ENGINE, 454 C.I.D. V8 (454S)
LF9 78 85 ENGINE, 350 C.I.D. DIESEL V8 (350N)
LG2 86 86 ENGINE, 3.8L V6 (3.8B)
LG3 77 78 ENGINE, 305 C.I.D. V8 (305U)
LG3 79 79 ENGINE, 305 C.I.D. V8 (305G)
LG4 80 86 ENGINE, 305 C.I.D. V8 (305H)
LG8 85 86 ENGINE, 5.0L V8(HI OUTPUT) (5.0-9)
LG9 77 81 ENGINE, 305 C.I.D. V8 (305G)
LH6 82 86 ENGINE, 6.2L DIESEL V8 (6.2C)
LH7 82 85 ENGINE, 2.8L V6(HI OUTPUT) (2.8Z)
LH8 82 86 ENGINE, 1.8L L4 (1.8-0)
LJ5 81 86 ENGINE, 1.8L DIESEL L4 (1.8D)
LK9 82 85 ENGINE, 3.0L V6 (3.OE)
LL1 83 84 ENGINE, 2.8L V6 (2.8L)
LL2 86 86 ENGINE, 2.8L V6 (2.8R)
LL4 82 86 ENGINE, 6.2L DIESEL V8 (6.2J)
LM1 77 82 ENGINE, 350 C.I.D. V8 (350L)
LM1 83 86 ENGINE, 350 C.I.D. V8 (CHEVROLET)
LM1 84 86 ENGINE, 350 C.I.D. V8 (PONTIAC) (350-6)(EXPORT)
LM9 84 85 ENGINE, 3.8L V6 (231-9)
LN3 84 86 ENGINE, 3.8L V6 (231-3)
LN7 85 86 ENGINE, 3.0L V6(HI OUTPUT) (3.OL)
LN8 85 86 ENGINE, 2.5L L4 (2.5E)
LP9 84 85 ENGINE, 5.7L V8
LQ2 83 84 ENGINE, 2.0L L4 (2.0Y)
LQ5 83 86 ENGINE, 2.0L L4 (2.0P)
LQ7 83 85 ENGINE, 2.2L DIESEL L4 (2.2S)
LQ8 82 83 ENGINE, 2.5L L4 (2.5F)
LQ9 82 86 ENGINE, 2.5L L4 (2.5-2)
LR1 82 85 ENGINE, 1.9L L4 (1.9A)
LR2 82 85 ENGINE, 2.8L V6 (2.8B)
LR8 82 86 ENGINE, 2.5L L4 (2.5R)
LR9 82 84 ENGINE, 2.0L L4 (2.0B)
LS2 85 86 ENGINE, 4.3L DIESEL V6 (4.3-7)
LS6 78 79 ENGINE, 151 C.I.D. L4 (151-1)
LS8 79 79 ENGINE, 151 C.I.D. L4 (151-9)
LS9 77 86 ENGINE, 350 C.I.D. V8 (350L)
LT5 76 81 ENGINE PERFORMANCE PKG,HIGH ALT
LT6 82 84 ENGINE, 4.3L DIESEL V6 (4.3V)
LT7 82 85 ENGINE, 4.3L DIESEL V6 (4.3T)
LT8 82 86 ENGINE, 4.1L V8 (4.1-8)
LT9 83 84 ENGINE, 350 C.I.D. V8 (PROPANE) (350K)
LT9 80 86 ENGINE, 350 C.I.D. V8 (GASOLINE) (350M)
LT9 86 86 ENGINE, 350 C.I.D. V8 (PROPANE) (350K)
LU5 82 82 ENGINE, 5.0L V8 (5.0-7)
LU5 83 83 ENGINE, 5.0L V8 (5,OS)
LV2 83 86 ENGINE, 307 C.I.D. V8 (HI OUTPUT: HURST) (307-9)
LV2 80 86 ENGINE, 307 C.I.0, V8 (307Y)
LV8 77 78 ENGINE, 260 C.I.D. V8 (260)
LV8 79 81 ENGIN5, 260 C.I.D. V8 (260F)
LV8 82 82 ENGINE, 260 C.I.D. V8 (260-8)
LW5 78 79 ENGINE, 1.6L L4 (1.6J)
LW9 80 83 ENGINE, 2.5L L4 (2.5-5)
LX3 77 77 ENGINE, 1.4L L4 (1.4)
LX6 77 78 ENGINE, 151 C.I.D. L4 (151V)
LX8 79 80 ENGINE, 151 C.I.D. L4 (151V)
LY5 77 78 ENGINE, 1.6L L4 (1.6E)
LY9 85 85 ENGINE, 1.0L L3 (1.OM)
LY9 86 86 ENGINE, 1.0L L3 (1.0-5)
L02 76 87 GENERATOR,100 AMP
L03 76 81 GENERATOR,110 AMP
L04 76 81 GENERATOR,145 AMP
L05 76 81 GENERATOR,130 AMP
L07 76 81 GENERATOR,145 AMP,DYNAMOTE PWR INVERTED
L11 77 77 ENGINE, 140 C.I.D. OHC L4 (140)
L13 76 76 ENGINE, 140 C.I.D. L4 (140)
L17 82 86 ENGINE, 1.6L L4 (1.6c)
L22 77 79 ENGINE, 250 C.I.D. L6 (250)
L25 77 86 ENGINE, 292 C.I.D. L6 (292T)
L26 78 79 ENGINE, 200 C.I.D, V6 (200)
L27 77 79 ENGINE, 301 C.I.D. V8 (301Y)
L32 77 77 ENGINE, 350 C.I.D. V8 (350H)
L33 78 79 ENGINE, 425 C.I.D. V8 (425)
L34 77 80 ENGINE, 350 C.I.D. V8 (350R)
L35 78 79 ENGINE, 425 C.I.D. V8 E.F.I. (425)
L37 78 81 ENGINE, 301 C.I.D. V8 (301W)
L39 79 82 ENGINE, 267 C.I.D. V8 (267J)
L44 85 86 ENGINE, 2.8L V6 (HI OUTPUT) (2.8-9)
L46 82 82 ENGINE, 1.8L L4 (1.8G)
L48 77 80 ENGINE, 350 C.I.D. V8 (350)
L49 78 80 ENGINE, 350 C.I.D. V8 (350B)
L54 86 86 ENGINE, 4,3L DIESEL V6 (4.3-8)
L61 80 84 ENGINE, 368 C.I.D. V8 (368-6)
L62 80 84 ENGINE, 368 C.I.D. V8 (368-9)
L65 77 77 ENGINE, 360 C.I.D. V8 (350G)
L68 85 86 ENGINE, 2,5L L4 (2.5U)
L69 83 83 ENGINE, 5.0L V8(HI OUTPUT) (305-7)
L69 84 86 ENGINE, 5.0L V8(HI OUTPUT) (305G)
L76 77 77 ENGINE, 350 C.I.D. V8 (350P)
L77 77 77 ENGINE, 350 C.I.D. V8 (350J)
L77 78 80 ENGINE, 350 C.I.D. V8 (35OX)
L77 81 81 ENGINE, 350 C.I.D. V8 (350B)
L78 77 79 ENGINE, 400 C.I.D. V8 (400)
L80 77 79 ENGINE, 403 C.I.D. V8 (403)
L82 77 80 ENGINE, 350 C.I.D. V8 (SPL HI PERF) (350)
L83 82 84 ENGINE, 5.7L V8 (5.7-8)
L91 76 81 ENGINE, EXPORT
L92 76 81 ENGINE, EXPORT
L93 76 81 ENGINE, VENEZUALA(EXPORT)
L98 85 86 ENGINE, 5.7L V8 (5.7-8
Old May 6, 2021 | 10:55 PM
barkingrats
You know the SS trim level existed in the Chevelles and Camaros in the 60s, right? Unlike the LT and LS engines being just an alpha option code, the SS stood for Super Sport; RS was Rallye Sport; GS was Grand Sport and GT was Grand Touring (but then I'm mixing marques). There were a whole host of trim level abbreviations across all manufacturers for cars that have become iconic.
Corvettes never had these trim level versions the way other lines did. Although they came with hood badges, you could order a fuelie, an LT-1, an LS-5, or any of the engines with many combinations of options rather than a set package. The option limitations existed due to operation of the accessory or to discourage street use.
Now we can put this to bed... or not.
Old May 7, 2021 | 07:28 AM
  #33
brushmor's Avatar
brushmor
I used to work for GM. Early in my GM career there was an all people meeting with an executive you would all know. At the end was the standard Q&A. Someone asked how GM comes up with the RPO codes. His answer was "nobody knows". Later in my GM career it made sense. It would be easier to answer what is the sound of one hand clapping than it would be to answer the OP's original question.
Old May 7, 2021 | 01:26 PM
  #34
derekderek's Avatar
derekderek
L means engine. S and T come after R. they used certain codes over because they got somewhat of a cult following. enough of a following the RPO code became the defacto model number-name. LT1 and LS6 are the best known. M21 and M22 come to mind.
Old May 7, 2021 | 02:39 PM
  #35
pspicci's Avatar
pspicci
40 years ago when i got my 71 i wondered what the LS stood for in the LS-5 code. the only thing i could come up with is i figured since the 454 had a longer stroke than the 427 and all the 454's that i was aware of began with a LS maybe it stood for long stroke. but probably not.
Old May 7, 2021 | 03:22 PM
  #36
hdal's Avatar
hdal
All kidding aside,we all know what "LSMFT" means,right? Hdal
Old May 7, 2021 | 05:47 PM
  #37
derekderek's Avatar
derekderek
engines are L. next 2 letters are probably decided in a bar down the street with ping pong ***** or something.
To What does "LS" in Chevy's engine stand for?
Old May 7, 2021 | 07:00 PM
  #38
jim2527's Avatar
jim2527
Lotsa Spunk
@Knooger approves
Old May 7, 2021 | 07:55 PM
  #39
Knooger's Avatar
Knooger
CI 6-7-8 Veteran
St. Jude Donor '06, '07, '11, '17
Originally Posted by jim2527
@Knooger approves
Correct.
Old May 8, 2021 | 08:42 AM
  #40
doorgunner's Avatar
doorgunner
2026 Loser of the Year
10-04-2009, 02:02 PM
vetteguy75
CF Senior Member
Support Corvetteforum!
vetteguy75's Avatar
LA Events Coordinator
Default What does "LS" in Chevy's engine stand for?
Like the question says...what does it stand for? I've looked (what I thought) was everywhere....
Light as S***.
Mystery solved.
Next question please
