Gravity Bleeding- Rear Only?
Old Oct 6, 2009 | 09:13 AM
RedZR's Avatar
RedZR
Default Gravity Bleeding- Rear Only?
All,
I need to change my rear calipers & pads on my 78. Can I simply gravity bleed the rear brakes only without screwing the fronts up?
Also, its my understanding that to gravity bleed you simply mount the calipers & pads, open the bleed screws, remove the master cylinder cover and let nature take its course (while making sure the master cylinder does not go dry). Is it that simple?
Thank you,
Dan
Old Oct 6, 2009 | 10:07 AM
flttester's Avatar
flttester
Yes, you can just bleed the rears - it is separate from the front. That's pretty much how gravity bleeding goes. Only do each of the bleeder screws individually.
Old Oct 6, 2009 | 10:32 AM
73StreetRace's Avatar
73StreetRace
But gravity bleeding the rear calipers takes some time
Old Oct 6, 2009 | 11:30 AM
VettePower's Avatar
VettePower
About 2 beers worth of time in the recliner. It's the only way to go!!
Old Oct 6, 2009 | 12:40 PM
mskvettefan's Avatar
mskvettefan
Good question as I hate bleeding brakes... I have noticed that my calipers which are Delco reman's have a bleeder on the inboard and outboard side of the caliper... does that mean both have to be bled out or just the outter, which would be furthest from the master cylinder?
Old Oct 6, 2009 | 12:45 PM
73StreetRace
But sometimes the gravity of the planet Jupiter would help !
Old Oct 6, 2009 | 12:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...About 2 beers worth of time in the recliner...
Sippin' slow...per wheel.
Old Oct 6, 2009 | 01:09 PM
Muddywaters's Avatar
Muddywaters
I bleed them all...right rear, outer, inner/ left rear, outer, inner Just keep an eye on the master reservoir. Muddy
Old Oct 6, 2009 | 01:15 PM
midyearvette's Avatar
midyearvette
gravity method works well if you have the time....don't forget...4 bleeders on the rear brakes!
Old Oct 6, 2009 | 03:29 PM
Easy Mike's Avatar
Easy Mike
Both halves of the rear calipers have to be bled. Bleed the inner half first, then the outer.
Old Oct 7, 2009 | 08:45 PM
flttester's Avatar
flttester
with everyone above - inner bleeders, then outers.
Old Oct 7, 2009 | 10:09 PM
dannyman's Avatar
dannyman
Originally Posted by RedZR
All,
Thank you,
Dan
Yes; gravity bleed. Resist the urge to depress the brake pedal until you have plenty of fluid at both of the rear calipers.
Old Oct 8, 2009 | 12:27 AM
Muddywaters
It's always been my understanding...to bleed farthest from the master (outer) to closer (inner). Must work both ways as I get the hardest peddle ever, and I'm using Dot 5 Muddy
Old Oct 8, 2009 | 01:05 AM
Peterbuilt's Avatar
Peterbuilt
This is just one of many endless debates, I like to bleed closest to the M/C first inner than outer, which for me is LR that RR. Than LF than RF. PG.
Old Oct 8, 2009 | 09:34 AM
Vette79C3's Avatar
Vette79C3
All,
Thank you,
Dan
After replacing my Rear Calipers and Master Cylinder, it was helpful using a rubber mallet to tap on the calipers to remove trapped air. But we did use a power motive bleeder unit.
Old Oct 8, 2009 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Service manual says:
LR, RR, RF, LF
On the rears, inner halves are bled first.
Old Oct 8, 2009 | 03:29 PM
midyearvette
LR, RR, RF, LF
service manuals contradict issues from time to time, evidentally both methods work as many do it your way, however i have always done the opposite....rr..lr..rf..lf....longest line first.....
Old Oct 9, 2009 | 03:18 AM
myoriginal77's Avatar
myoriginal77
I let my wife pump the pedal the old school way, this is one of the things she does best ....
Frank
To Gravity Bleeding- Rear Only?
