If you've got the time, tools, and the inclination...go for it. The Chevrolet Chassis Service Manual has complete details and instructions in Section 4 (Rear Suspension). You should review it and what is required before you decide to attempt it.
I did mine a couple months ago. You will need a dial indicator and the spindle tools. They can be rented. It's no big deal. Take your time when setting up the bearings and take careful measurements. The hardest part will be getting the trailing arm bolts out. Anyone with mechanical ability can do it.
You will need some special tools to do the wheel bearings.
Within a very short period the preload on the bearings will change. It is important to get it close, but a very good set of bearings if pulled and checked will be out of spec, but dont need changed. The important thing is to use the correct spacer. I have changed many many rear bearings in differnt neglected cars and never had one fail yet and did not use a bearing preload tool. Just my 2 cents.
trailing arms are out.The mighty sawzall.I'm rebuilding the entire frame and buying rebuilt or having the trailing arms rebuilt I found to be a little over the top.I noticed a lot of rebuilding services are expensive.Even the front A arm rebuild is expensive.I rebuild dozens of the over the years,no big deal.I figure I'll take a shot at the rear T arms.
What constitutes having your T/A's rebuilt? What are the obvious reasons? Mileage? Rust?, I think I may know a few, but I would like to hear from a couple of folks why/when this job should be considered.
Thx,
Doesn't matter how many tools you have, you will need to buy/rent/make some special tools to do the job right!
I rebuilt mine because they were original (1968, 82k miles), and the trailing arms were rusted. One side was almost devoid of grease and would've failed soon IMHO. Not a tough job if you have good reference materials/advice. Get a copy of the GM shop manual, and check out GTR1999's thread. Do a forum search if you get stumped
I used the shims from the kit, and got .0019 and .003 endplay, but I was lucky; once you are to the point of setting up your bearings, plan on ordering the exact shim thickness you need from Gary or Vtech.
I used Jacobs Corvette's Coraopolis, PA. 1-412-264-9151 Mr. Harvey I rebuilt one on my 80 and I needed all kinds of tools.. This guy will give you a warranty and they look wonderful. Give him a call to check prices. I think he's been in business for the last 25 years. Have a great day. Gene
I opted to send mine to Vtech corvette, Gary does fantastic work. Spindle end play came back @ .001, rotor runout was .002 & .0025 with my year old Slotted rotors from R1 concepts. Gary called me only after 5 days, I still cannot believe the Quality for $610 ( excluding shipping) including the $40 SS alignment shims, I bought from him. He through in the 2 long SS cotter pins, and gave me one of his Hats. Gary is great guy to deal with. Period. He knows his stuff. Check out these shots of his work.
