anyone using a remote starter solenoid?
All u have to do is draw the electrical schematic to see adding more solenoids in series only adds more contacts and drops more voltage.
To say u can bypass the original solenoid with one on the fender is totally false!If u what to reduce heat soak then you need to install a functional heat sheild. You can look in my signature link http://members.cardomain.com/cardo0 at the JC Whitney sheild i installed for $15 and it has proved itself in >100*F temps in city traffic.
Get the truth out,
cardo0
I just use the original starter with a high quality solenoid on it.
To do the conversion properly, a solid copper or brass bar is usually connected from the starter batt term to the s term and when the solenoid, relay, contactor is energized, both get full battery voltage.
BTW, Ford had a recall on their later mini starters for a bad s connection, even though they used the large solenoid so nothing is foolproof.
When installing a remote solenoid properly,
you no longer use the factory solenid to switch the 12Volts,
the remote solenoid supplies power to the starter and the solenoid bendix,
at the same time via a small jumper.
When you are not starting there is 0 power going to the starter.
It makes things safer, and no one can jump start (steal) your car,
with jumpers at the starter. You are replacing the OEM. solinoid switch not adding in series.
When you use a remote you attach your starter cable "Directly to Motor connection",
and add a small jumper to the "S" terminal."
you are bypassing the switch in the OEM. solenoid,
and still using the bendix to kick the starter into the flywheel. 69VETT
Heat shields/wraps and the mini starters are a waste of money unless you need high torque starting - IMO of course.
The large cable to the starter still connects in the same place as it always has.
The original solenoid still has to do the same job it always has, engaging the starter drive gear and making the internal electrical connection.
What is improved is that the S terminal gets full battery voltage, which improves the operation of the solenoid.
And for those using a "wrap" my opinoin is once the starter heats up a "wrap" only serves to hold heat in the starter/solenoid.
To reduce heat soak we need a shield with an "air gap" between the starter to allow air flow and convection heat transfer away from starter.cardo0
To fix a heat-soak problem - stop buying cheap starters, and get rid of your headers. If no headers is not acceptable get a good, quality starter (especially a quality - again, not Chinese - mini-starter) because it will reduce the number of times you have to replace the starter - but if you're looking for reliability, drive down to the Toyota dealership and trade your Corvette for a nice, pink Camry.
The point of a Ford solenoid is to remove the power from the main lug on the starter in all situations except when the starter is being engaged. That second solenoid reduces a large fire hazard. A side benefit is that the wires that power your car will have less resistance (voltage drop) because heat is the enemy of electrical flow.
These type of starters you can wire either way.
GM wired theirs this way as well.
Here is a GM wiring diagram.
Nothing substitutes for cleaning all the battery cable connections and other wire connections to raw metal and using something like antisieze or dielectric to keep them from oxidizing prematurely.
I had this problem before headers and with a new OEM starter, same story as many others.
You obviously do not know what you are talking about, so why not troll somewhere else with your pink made in another country mini starter! Someone posts for help and advice, not meaningless BS! Why are you even on the forums?
Tagg99: The FORD - made in the USA part works great! Has continued to work for me for the last 4+ years with absolutely no problems even with Hooker side pipes. I will look for my how-to information and send you a PM.
http://www.google.com/url?sa=t&rct=j...a2IwU64Zzw2O3Q
hope this helps
btw they still put them on chevy diesel trucks
serious old school , but back in the day you could install this
GM#1958679
inside your chevy starter solenoid...also, didnt work as well
If nothing else, this makes it very easy to connect a remote starter button. I like it and bought it from Mad Electrical http://www.madelectrical.com/catalog/st-1.shtml
My starter only has one big cable connecting to it.
Installed ford solinoid on firewall my 66 big block .... many years ago heat soak problem totally resolved .. did this many years ago "works for me " & my 66 is happy ..kit availble from summit & comes with wiring diagram .................
