question for the motor heads
Old Oct 9, 2009 | 04:15 PM
mvette76's Avatar
mvette76
Default question for the motor heads
two heads with the same runner volume valve size and combustion chamber but one flows 20 cfm's more at a certain valve lift how much power difference is this going to equate to? this is according to each manufactures specs!
Old Oct 9, 2009 | 04:35 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
A rule of thumb for a properly built pump gas high performance motor is ~+/- 2HP per CFM. I am talking about a motor built with the correct matching parts.
My previous 406ci had heads on it that flowed ~280cfm and made 547HP on an engine dyno with no tuning
Old Oct 9, 2009 | 04:52 PM
mvette76's Avatar
mvette76
so the to heads I'm looking at are the brodix ik180 or the afr 180 street eliminator on a 350 9.5 comp. gm hot cam rpm intake Holley 750 vac. 1 5/8 headers 2.5 magna flows th400 3:73 gears . so my dilemma is are the afr heads on my combo worth the extra money
Old Oct 9, 2009 | 05:10 PM
MotorHead's Avatar
MotorHead
If your cam lifts the valve high enough to take advantage of the extra 20cfm then yes they are worth the money. You also look at the midrange numbers and compare how much better the AFR's flow there too. I have AFR227's that flow 320+cfm and I think they are worth every cent I paid for them
Old Oct 9, 2009 | 06:14 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I would go with the AFR's. Price difference is under $400 for close to 40 HP. You will feel that difference in your wallet and the seat of your pants.
Old Oct 9, 2009 | 10:50 PM
dp9's Avatar
dp9
just curious, are they the eliminators or the older style? race ready or comp ported?
Old Oct 9, 2009 | 11:14 PM
MotorHead's Avatar
MotorHead
They are the RR Eliminators
Old Oct 11, 2009 | 09:04 AM
Neptune75's Avatar
Neptune75
Afr!!!!!!!!! they pull all the way across the rpm range.. not just peak numbers. they are worth the $$$$
To question for the motor heads
