carb replacement
Old Oct 10, 2009 | 11:07 AM
xpoc454's Avatar
xpoc454
Default carb replacement
I have a 69 427 4 speed car with some carb issues. Rochester quadrajet.
The carb that was on the car when I bought the car decodes to a 71 350 truck carb. Not only does it appear to not be large enough it doesn't quite fit right on the intake (has some wierd linkage).
The car came with what I was told was the original carb but it decodes to a 68 427. Pretty close, so I took it in to get it rebuilt and was told and witnessed, that the threads for the fuel inlet are stripped and pretty much unrepairable. He said that a helicoil could be put in but Im thinking once that is done the rebuild is going to cose the same as a new one and not be original anyways.
Since the carbs I have are not original I was wondering what people thought were some alternative and good options?
Should I go with a place like chicago corvette supply that has carbs for my year that are remanufactured?
http://www.chicagocorvette.net/item....=23605&rc=1939
219$ seems fair but I assume I have to pay shipping to send in core and shipping to receive the new carb. That, I would assume, is going to be a total of at least 30$ more in shipping alone.
Is it going to be cheaper just to go a local parts store and buy a a remanufactured carb?
If I try to sell the carb on ebay with the stipulation of saying the carb neds rebuilt and the threads are worn, will it give me more money than what I would get for a core charge by chance?
thanks for any answers
jim
Old Oct 10, 2009 | 03:02 PM
Project80's Avatar
Project80
Jim,
Your situation is not uncommon, do a "Search" and look over the previous quadrajet posts.
Old Oct 10, 2009 | 03:35 PM
Mike Ward's Avatar
Mike Ward
Qjets don't come in different sizes externally. You were given good advice in your other thread(s) that asked essentially the same questions.
Old Oct 10, 2009 | 04:05 PM
a1sensei's Avatar
a1sensei
I would not buy an aftermarket carb (downgrade from the Q-jet and usually more $ than rebuild) or a rebuilt Quadrajet from a discount parts store (commercial rebuilds are known for carb destroying shortcuts).
A rebuildable core for a Q-jet on Ebay will bring an average of about $25.
If the guy that is going to heli-coil your BB carb knows what he is doing, I'd go that way. I might have a BB rebuildable core (not correct for your year) lying around here that I could build for you for a bit less, but there would be a bit of a wait. PM me if interested.
God bless, Sensei
Old Oct 10, 2009 | 06:13 PM
xpoc454's Avatar
xpoc454
What I would call the throttle linkage is what im talking about. The 68 carb looked ok but when I put the carb that was on the carb when I bought it back on after doing some work, I noticed there on the linkage was more than normal. The carb had some metal that hung down that would get caught on a intake manifold bolt. It probably made since on a diferent intake but didnt on this one.
Old Oct 10, 2009 | 07:03 PM
Ganey's Avatar
Ganey
...The car came with what I was told was the original carb but it decodes to a 68 427. Pretty close, so I took it in to get it rebuilt and was told and witnessed, that the threads for the fuel inlet are stripped and pretty much unrepairable. ...
You can get a self tapping fitting to fix fuel inlet at auto parts in Help section & rebuild yours.
Old Oct 10, 2009 | 09:46 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
I replaced my Q-junk with a Barry Grant Demon carb.
Old Oct 10, 2009 | 11:30 PM
baxsom's Avatar
baxsom
just had to open the worm can didnt you
Old Oct 11, 2009 | 12:40 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
The 350 carbs have a metal tab on the linkage that the 454s don't have. As far as being interfered with on the engine, I don't know, but they are there. I'm trying to find a pic....
I am sending you a PM on the fuel inlet.
Old Oct 12, 2009 | 06:06 PM
stingraymyway
Let the games begin......
Old Oct 12, 2009 | 07:28 PM
Paul L's Avatar
Paul L
No wonder Lars left.
Old Oct 12, 2009 | 09:18 PM
thegazman's Avatar
thegazman
Default thegazman
Jim....While you are checking around....Check with Jet Performance. They build performance q-jets specifically jetted for big blocks.
Old Oct 13, 2009 | 02:32 AM
eguyett1985's Avatar
eguyett1985
Try Shawn Murphy at SMI Carburetion
http://www.smicarburetor.com/
He has built me several Q-Jets over the years and his carbs are excellent right out of the box and his service is top notch.
Old Oct 14, 2009 | 08:32 AM
base1957's Avatar
base1957
I used a quick fuel on my 402. Very quick response
To carb replacement
