Carburetor idle screw question
Old Oct 10, 2009 | 09:20 PM
sabre1981's Avatar
sabre1981
Default Carburetor idle screw question
I have an '81 and bought a used '81 carburetor. My friend has been rebuilding it and has it back together, however, we are both unsure of how many turns the idle screws are supposed to set at.
Old Oct 10, 2009 | 10:15 PM
mds3013's Avatar
mds3013
As a starting point lightly seat screws all the way in. Then back each screw 1 1/2 turns out. Car should start at this setting. Proper tuning is done when highest manifold vacuum is attained. mds...
Old Oct 11, 2009 | 01:15 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Bench setting for an older car should be around 4 turns. This will ensure plenty of idle fuel upon fist start up.
A quick, easy adjustment once running is.....get the engine up to operating temp. Lower the idle speed to as low as it will go(most times, this will be backed out to where the screww is not toucing the throttle. Screw one mixture screw in until the idle gets rough. pull it back until it smooths out and go an additional 1/4 turn. Do the same for the other side. Set your idle speed back to normal.
It is best to use a dwell gauge to make the proper settings, but this will get you by until that can be done.
To Carburetor idle screw question
