Carb info
Old Oct 11, 2009 | 10:34 AM
mstrong52's Avatar
mstrong52
Default Carb info
I have a quadra jet and want to install a larger carb. I have a 350 with an edelbrock aluminum intake and headers.Looking for. recommendations
Old Oct 11, 2009 | 10:50 AM
Ganey's Avatar
Ganey
So far it sounds like you only need 600-650.
See CARBS Tests TQ/HP
http://www.corvettefaq.com/c3/carbcomparo.htm
Old Oct 11, 2009 | 10:58 AM
mstrong52's Avatar
mstrong52
Holley or Edelbrock? Do I want the double pumper or not?
Old Oct 11, 2009 | 11:18 AM
Ganey's Avatar
Ganey
Holley 600-650 vac. sec., probably not DP.
Old Oct 11, 2009 | 11:29 AM
mstrong52's Avatar
mstrong52
REBUILT HOLLEY 0-84021 SPREADBORE 650CFM CARBURETOR
Please waitImage not availableEnlarge
Item condition: Remanufactured
Time left: 6 days 23 hours (Oct 18, 200907:35:29 PDT)
Bid history: 0 bids[Refresh]
Starting bid: US $99.95
Enter maximum bid: US $
Place bidPlace bid
(Enter US $99.95 or more)
or
Price: US $119.95 Buy It NowBuy It NowBuy It Now
You can also: Watch this item
Now watching in My eBay Now watching in My eBay
Is this what I need?
Old Oct 11, 2009 | 11:50 AM
7T1vette's Avatar
7T1vette
Your Q-jet has 750 cfm (capability) by its design..."bigger" than the other Holley's you are considering. Plus, it is more economical when you aren't stomping the pedal; and, since you already have it, it's FREE! It is a more sophisticated carb than a Holley and nothing sounds quite like a Q-Jet when you go WOT. Why do you want to swap it out? It's a better carb. For most 350 engines, Holley's have more 'reputation' and 'image' than actually being any better.
Old Oct 11, 2009 | 12:13 PM
mstrong52's Avatar
mstrong52
I may be mis-informed. I have been told I would have better response ditching the Qjet for the edelbrock or Holley. Thank you for your candor.
Old Oct 11, 2009 | 12:57 PM
Matt Gruber's Avatar
Matt Gruber
i had a q-jet in the 80's and, once i adjusted the air valve for a quicker response, i was happy with it.
i'm now a holley guy, but i wouldn't replace a Q that works well.
Buy new heads!
Old Oct 11, 2009 | 03:49 PM
c31980's Avatar
c31980
Old Oct 11, 2009 | 04:19 PM
marz's Avatar
marz
They did a rebuild feature on Musclecar and found you could get great performance from the Q Jet, but it took a total rebuild and some jet/pump changes. It really made a great deal of power and you could make it breathe to 800 cfm. It looked like a complicated rebuild.
There is a reason most motors are sporting Holleys/Edelbrocks/Demons. They make great power and are easily rebuilt or enhanced. You haven't mentioned if the cam/heads are stock? 750 cfm is probably about right for your motor.
Old Oct 11, 2009 | 11:08 PM
7T1vette's Avatar
7T1vette
There is nothing really complicated about getting a Q-Jet to function well. Getting it to function as well as is possible (for the design of the carb) is more difficult and requires specific knowledge that most of us {including me} do not have. But, the same thing goes for a Holley or any other carb; if you know the "tricks" you can make it work better. A Q-Jet that is rebuilt with a quality kit and adjusted properly will work better [in all categories] than a Holley of comparable size that is purchased "off the shelf". Rebuild your existing carb and take the time to do so carefully, with the intent on learning about how it works and setting it up as best you can. Buy a book or two from the experts and read them to guide your work. The books and rebuild kit will cost a lot less than a new Holley, and you can take pride in the work you did, the knowledge you gained, and the performance improvements that YOU achieved.
Old Oct 12, 2009 | 03:54 PM
marz's Avatar
marz
That episode rebuilding the Q Jet was on again this past Sunday. Find the episode and watch them rebuild it. Good viewing. It can make a lot of power. Too complicated for me, but that's just me. I eventually installed a 750 Speed demon, but still had to play with jet size.
To Carb info
