Horn needs a good whack
Oct 12, 2009 | 06:01 PM
My horn needs to be pushed or hit hard to work, it works when I do that, but it seems like it needs a bit too much force.
I have tried removing one of the shims that's in there, but that makes the horn too sensitive/won't turn off.
Any tips on how to find a happy medium better 1 and 2 shims?
Side note: on of the three plastic pins is missing, not sure if that makes a difference.
Oct 12, 2009 | 07:34 PM
You need all 3 pins or it won't work correctly.
Oct 12, 2009 | 07:47 PM
I have the original steering column (swapped for T&T).
Can those pins be removed and reused?
Oct 30, 2009 | 12:16 AM
Quote:
Originally Posted by
...Roger...
My horn also needs a good smack to work. What 3 plastic pins are you referring to, and where would we buy them?
Oct 30, 2009 | 01:59 AM
I think the plastic rivets your asking about are on the horn contact.
Oct 30, 2009 | 02:02 AM
This is the view from the bottom.
Oct 30, 2009 | 02:07 AM
Zip and other vendors sell them but another forum member said True Value may have them
PS. Can someone tell me how to post more than 1 picture at a time?
