Heat Riser Question.
Old Oct 28, 2009 | 12:41 PM
Peterbuilt's Avatar
Peterbuilt
Default Heat Riser Question.
The heat riser never seems to open even after a long ride, untill I have time to change it can I just wire it open?
With it staying closed does that lower the MPG?
Old Oct 28, 2009 | 01:14 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
You can wire it open. You can also buy a spacer instead of the heat riser. It will most definitely effect your mpg if it is closed. You effectively cut off the exhaust flow on the right bank which isn't "efficient" to put it mildly. You can try to free it up with some penetrating fluid like WD-40 or PB Blaster. But I would replace it.
Old Oct 28, 2009 | 02:59 PM
Aggitated Monkey's Avatar
Aggitated Monkey
In the closed position it could cause heating problems also. It needs to be open.
Old Oct 28, 2009 | 03:39 PM
noonie's Avatar
noonie
Previous thread, different style, but wiring is at least a good temp fix.
Originally Posted by noonie
I just drilled a little hole and used some copper house wire. Can't really see it installed. Should be able to do it without removing.
Old Oct 29, 2009 | 02:38 AM
Peterbuilt's Avatar
Peterbuilt
Default Thanks for all the suggestions.
I'll try the PB a few times over the weekend and see if that helps. The riser has been in there since I got the car 10 years ago so I'm sure it's past its life expectancy. If I push it down about 3/4 of the way it will pop back up, but if I push it down all the way it gets stuck but than after a ride it is back up again. If the PB does not fix it I'll order a new one.
Looks like a simple thing to change but I know from other cars that those bolts seem to need a lot of heat to loosen up. If the PB doesn't help any I'll order a replacement.
Just wondering, I live in NC and the car leaves the garage in winter at 55*. can I get away with a spacer rather the the heat riser valve?
Would that just take the choke a few minutes longer to fully open?
Thanks again for everyones advise. PG.
Old Oct 29, 2009 | 03:19 AM
TimAT's Avatar
TimAT
In NC, you'll never notice the difference. In Fairbanks, Alaska, you will. Toss it in the trash. Install the spacer.
If PB doesn't work, stop by your local airport- the FBO (if they work on little airplanes) will have a little bottle of stuff called "Mouse Milk". try a little of that, or some Hoppe's #9 Gun Solvent.
Old Oct 29, 2009 | 03:51 AM
Peterbuilt's Avatar
Peterbuilt
Default Great Advise!
In NC there is a gun shop on every corner and a few small airports on every few miles. My boss had a meeting last week and stated that if you do not use your 6 sick days before the end of the year we can no longer carry them over to the next year and any vacation days not used will be forfeted when the new year begins, so I'll be calling sick tomorrow and have time to search for the Milk Mouse and Hoppe's #9 gun solvent you mentioned, thanks.
Buy the way he now says we have to pay half the medical on our own which will cast $40.00 extra per week. I doubt that I'm going to be long on this job. PG.
Old Oct 29, 2009 | 10:29 AM
Tom454's Avatar
Tom454
GM & others sell a high temp rust penetrant and heat riser lubricant. Run of the mill penetrants will burn off quickly.... the correct lubricant will not.
Edit:
AC Delco Part 10-6000
88900415
Rust Penetrant and Inhibitor
Contains a special blend of solvents and lubricants
Dissolves rust and corrosion to loosen nuts, bolts and other fasteners
Lubricates heat valves and removes manifold deposits to ensure correct heat valve operation
Old Oct 29, 2009 | 01:22 PM
SSG26K's Avatar
SSG26K
Your heat riser is vacuum controled. Unplug the vacuum hose at the actuator and see if it opens. If it does you need to change the thermal vacuum switch or just plug the TVS with a golf tee and forget about it. The heat riser usually isn't the problem. It's normally open and is closed by vacuum through the actuator.
Old Oct 29, 2009 | 05:01 PM
TimAT's Avatar
TimAT
FWIW: Mouse Milk is used to lube the turbocharger wastegate on light aircraft. Good stuff.
Probably the same as that GM stuff for 2x the price.
Old Oct 29, 2009 | 05:35 PM
RedZR's Avatar
RedZR
Default Heat Riser Question. Reply to Thread
How do you know if the heat riser is open or closed? On my 78 if I disconnect the vacuum line the thing moves in the opposite direction (that it was in with it applied).
Dan
Old Oct 29, 2009 | 06:46 PM
grandmastercorvette's Avatar
0grandmastercorvette
Former Vendor
Pete,
You engine's heat riser should NOT be vacuum controlled. That came in 1975-79.
Yes you can wire it up...but may take the choke to stay on a little biut longer...if you drive it when it is cold out.
It is an easy replacement...due to the nuts should not be frozen on ...due to your engine rebuild you did a short while ago. I would apply a little penetrating oil on a Q-tip and then apply to the threads of the exhaust manifold..instead of shooting the stuff and making a mess on your clean car....and having it burn off due to being soaked.
It is a part that you can pick up locally...instead of paying for shipping. Just make sure that you also get the gasket that goes between the exhaust manifold and the heat riser. And it would be a good idea to have on hand the donut gasket also.
"DUB"
Old Oct 30, 2009 | 12:50 AM
eguyett1985's Avatar
eguyett1985
I just picked up a spacer from these guys for a 72 I'm doing. Looks like a nice piece:
http://store.heartbeatcity.net/store...cer%2C-all-SB/
Old Oct 30, 2009 | 02:24 AM
Peterbuilt's Avatar
Peterbuilt
Thanks everyone for all the help and suggestions, I'll dab some penetrant on the moving parts for a few days and then get the AC Delco penetrant if that doesn't help.
Some times a day at work is easier than staying home, ended up putting in a new light fixture in the kitchen and than mowing the lawn, got to keep the better half happy if you know what I mean! PG.
To Heat Riser Question.
