How to adjust standard shifter?
Old Oct 14, 2009 | 03:05 PM
highschool67's Avatar
highschool67
Default How to adjust standard shifter?
I have a standard muncie shifter, chrome handle with "t" pull up reverse and was wondering the steps to adjust the shifter. It is on my 72. It seems the shifter hits the shifter bezel in 1st and 3rd.
Dave
Old Oct 14, 2009 | 05:25 PM
MelWff's Avatar
MelWff
try this link http://willcoxcorvette.com/repairand...0ff99e9620c03f
Old Oct 14, 2009 | 05:35 PM
...Roger...'s Avatar
...Roger...
You'll also need to make this gauge.
Old Oct 14, 2009 | 06:14 PM
Alan 71's Avatar
Alan 71
Hi H67,
If your metal working abilities are limited, (like mine),you can make the guage that Roger showed (and you need) from a stiff plastic putty knife from the hardware store!
Regards,
Alan
Old Oct 14, 2009 | 08:40 PM
highschool67
What is the total width of the tool?
Is the one measurement 644 thousandths?
Thanks Dave
Old Oct 14, 2009 | 09:11 PM
...Roger...
Never noticed that was missing. It started out as 3/4" wide putty knife. I copied that out of a GM shop manual. The .644 is the important part. Here is the one I actually use when the shifter is in the car.
Old Oct 14, 2009 | 09:44 PM
lakensea's Avatar
lakensea
If you move the swivels down to the lower holes it will shorten the throw and keep the shifter from hitting the bezel.
Old Oct 14, 2009 | 10:00 PM
trw's Avatar
trw
Check to see if you have washers under the front of the shifter bracket (2) in picture.
If you do take them or one out.
This moves the shifter front to back.
Hope it helps.
Terry
Old Oct 14, 2009 | 10:12 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Nice background... Showing off the ride again I see!
To How to adjust standard shifter?
