Stepped headers
Old Oct 15, 2009 | 07:23 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Stepped headers
Which way do they normally go ? If you had long tube undercar headers like say Hooker Super Comps with 1 3/4" primaries would you gain anything buy stepping the pipes up to 1 7/8".
What I mean to say is you start with 1 3/4" and step them up not down, anyone know ?
Obviously I have never run them but I always thought you stepped them down ?
Old Oct 15, 2009 | 07:49 PM
Ironcross's Avatar
Ironcross
I use the super comps and the primaries are 2 1/8 into 3 1/2 collectors....only problem is the ground clearance is close...But the tracks are smooth and flat so that issue is not much of a problem....some return roads/lanes are bad however...Just watch for holes and bumps......
Old Oct 15, 2009 | 08:21 PM
fauxrs's Avatar
fauxrs
Stepped headers start large at the heads and get smaller as they progress away from the port if I'm not mistaken. I believe the concept is as the exhaust cools, you reduce tube size to keep velocity up to enhance the scavenging effect.
At least thats how I understand it.
Old Oct 15, 2009 | 09:40 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Other way around....
Old Oct 15, 2009 | 09:50 PM
MotorHead's Avatar
MotorHead
Can you do it both ways or is the smaller to bigger the way to go.
I have a guy that is going to make some stainless headers exactly like the Hooker Super Comps but step them up to 1 7/8" from 1 3/4" at the head. He wants to know if this would work well.
Sound like a good idea ?
Old Oct 15, 2009 | 10:14 PM
dp9's Avatar
dp9
smaller to larger. starts out small to maintain velocity which increases torque, and then goes larger for higher rpm flow. stepping them down would just be adding a restriction right after the head. at least thats what i read in one of the mags. who knows if they are correct or not. i think hedman calls theirs Tork-Step headers for that reason tho.
also, I'd love to buy a pair for my small block but cant find any for C3s
Old Oct 16, 2009 | 03:43 AM
vette427-sbc's Avatar
vette427-sbc
I would think that stepping them down will increase exhaust gas velocity, but at the expense of creating more back pressure. Stepping them up creates a venturi effect which pulls more exhaust gas out to fill the larger volume of the tubes after the step.
small world dp9, Im at exit 109 on the GSP. Not too far from you
Old Oct 16, 2009 | 04:55 AM
Little Mouse's Avatar
Little Mouse
If he is going to make all new stainless headers copied off the hookers just go 1 7/8 all the way on the primaries. 1 7/8 is ideal for a 427 keep the collector 3 inch dia., longer length in collectors helps torque.
Old Oct 16, 2009 | 09:16 AM
MotorHead's Avatar
MotorHead
He says he can't do that for some reason, actually says they don't fit. I sent him a link to the 1 7/8 inch side mount headers for small blocks, we will see.
Old Oct 16, 2009 | 09:59 AM
fauxrs's Avatar
fauxrs
cool - learn something new everyday
Old Oct 16, 2009 | 10:29 AM
Little Mouse
How the hell would you have a wider big block with everything from 1 7/8 to 2 1/8 primaries under chassis in a vette but you can't have a small block with 1 7/8 primaries. if he won't do it find someone else. My opinion most small block headers the collector is to short consider a good length on the collector whithin limits. big block headers use longer everything, with you SB your now at big block cubes at least in the past BB cubes.
You can put a rat motor in a vette chassis with 2 1/8 primaries but you can't put a SB in the same chassis with 1 7/8 primaries.
All the money your going to spend on custom headers may as well get picky get everything you want.
Old Oct 16, 2009 | 11:29 AM
MotorHead's Avatar
MotorHead
No room to put the bigger pipes between the bolt holes on the normal 23 degree heads, ever noticed how close the bolts are to the pipes even with 1 5/8 primaires ?
BTW this guy is going to sell these headers to C3 owners, if he ever gets them made
Old Oct 16, 2009 | 01:24 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
You step them up larger as you go. Several things come into play. It reduces reversion pulses back up the header. *Where* to put the steps is a little scientific to be correct. Many variables to get it perfect...but you can get close enough.
Do a search on PipeMax and Larry Meaux.........great stuff on exhaust flow.
JIM
Old Oct 16, 2009 | 01:32 PM
yellow-fever's Avatar
yellow-fever
This may be a little off topic, but I have wondered if changing from my Hooker Super Comps with 1 7/8" primaries, 3" collectors, and a 3" system all the way back to side-mount Hookers with 2 1/8" primaries and 4" collectors & pipes would make a big difference in HP on my mildly built 454?
Have you other guys that have gone to Hooker side pipes seen a big HP increase on a big block?
Old Oct 16, 2009 | 02:35 PM
Little Mouse
Ok that makes sense. Looks like you will have to come out a little ways then step up to 1 7/8.
Old Oct 16, 2009 | 02:45 PM
midyearvette's Avatar
midyearvette
that's the way the nascar guys do it....each team has a header guy and all he does is fab up systems for different race tracks and always smaller to larger.....
Old Oct 16, 2009 | 03:00 PM
lvrpool32's Avatar
lvrpool32
My Stahls step up.
Old Oct 16, 2009 | 03:21 PM
Ironcross's Avatar
Ironcross
These are polished stainless with equal length tubes into a 3 1/2 collector and out through 36 in megaphones. Larson Engineering made them for me and did most of my custom work on the ski and drag boats...the equal length tubes are the important item and hard to get under a Vette...
To Stepped headers
