prestone AS101 is all I can research they have ?
wonder what the difference is ??
It contains no acids and also doesn't clean nearly as well.
Have tried it before.
and before anyone jumps on the damage the radiator thing,
using the original formula, if your radiator leaks, then it was on it's last legs anyway.
The part number is 88861344. This cleaner actually utilizes an acidic cleaner to remove any severe debris from the system and then a neutralizer to stop the acidic cleaner. It is basically a two step cleaner.
OK Feller's here is the scoop !!!
NOONIE is Correct !!
The stuff I got is the #12346500 , it is in a Yellow Prestone Cardboard Container ...( like a Pringles Chip Can) It has 2 lids , 1 on ea. end > one half contains the Acid the other contains the Neutralizer
It was $ 6.23 after discount and the dealer said last one , on their computer it shows the PN# change
will it be the same stuff ??? they can't tell but probably not as he did not have any either to look at.
I'm working out of town but when I get home I'm going to see if my local dealer can track down some more for future ?
Thanks for the input guys !!
THANK YOU NOONIE !!!
