74 with strange electrical issues
Old Oct 18, 2009 | 11:16 AM
mstrong52's Avatar
mstrong52
Default 74 with strange electrical issues
Sometimes the engine still runs after cutting off the ignition switch. Pulling the light switch on or off sometimes shuts off the car. Also, dash lights seem to not operate unless the A/C selector dial is on in any position other than off.
I changed out the alternator thinking the diode was bad and backfeeding, but obviously this didn't help. At this point I swapped the ignition switch. Still no solution. Anyone wanna chip in there 2 cents?
Old Oct 18, 2009 | 12:27 PM
'75's Avatar
'75
Try unplugging the 2 wire connector from the alternator and start the engine and see if it turns off correctly. The results of that will give us a better idea of the problem.
Old Oct 18, 2009 | 12:50 PM
mstrong52's Avatar
mstrong52
Sometimes with the old one it would work and other times it didn't matter, that's why I changed out the alternator's 2 wire connector.
To 74 with strange electrical issues
