Adjustable Strut with Poly Bushing Failure
Old Oct 21, 2009 | 04:09 PM
texbeasr3's Avatar
texbeasr3
Default Adjustable Strut with Poly Bushing Failure
I replaced my rear struts with the adjustable kind and poly bushings, about 1.5 years ago. Trailing arms where also rebuilt, about 2 years ago. Since then I have put about 500-1000 miles on the 78 corvette.
This week, I noticed that the passenger side rear tire top was leaning inward, severely. So I was ready to readjust the strut, but found the lower bushing (nearest the tire) was completely deformed and over stressed. Driver side still looks ok, but also lean inward slightly.
Before I replace the bushings in the adjustable struts, is there another cause for the poly bushing failure. I think there is excess differential yoke end play. Would this cause the strut bushing failure?
Old Oct 21, 2009 | 05:28 PM
69vettester's Avatar
69vettester
If you dont notice any other abnormal wear by pulling and shaking everything, It may be possible you set that side up wrong a year ago and are just now seeing the results. That would be the best scenario to have happened.
Old Oct 21, 2009 | 06:01 PM
Belgian1979vette's Avatar
Belgian1979vette
The struts do not only rotate but also move axially. Poly doesn't withstand that too good.
Old Oct 21, 2009 | 08:12 PM
7T1vette's Avatar
7T1vette
I'm no expert, but poly doesn't have a lot of "give" and that could have hastened its demise. Try syntetic rubber on the replacements and see how they work out. 1000 miles to failure would indicate that the material was defective [to begin with] or that material is incapable of performing that function.
Old Oct 21, 2009 | 10:34 PM
Mike Ward's Avatar
Mike Ward
Originally Posted by 7T1vette
: that material is incapable of performing that function.
I'd go with that. Poly is not a good choice in this application and is an attempt to fix a non existing problem.
Old Oct 22, 2009 | 12:48 AM
gkull's Avatar
gkull
You have something bad going on. Your diff yokes are probably completely missing the tips clear down to the keepers allowing excessive lateral movement.
The poly end struts are a vast improvement over OEM rubber bushing guys!
Old Oct 22, 2009 | 03:01 AM
WESCH's Avatar
WESCH
Hi
Yes, if you use the Heim eyeball ends.
I also use the fixed poly end fittings and find lots of torsional movement deforming the bushings.
Next replacement will be the eyeball end fittings.
Rgds. Günther
Old Oct 22, 2009 | 06:53 AM
FB007's Avatar
FB007
That would depend on the application. Poly has very little compliance.
Old Oct 22, 2009 | 09:25 AM
gkull's Avatar
gkull
Well my poly end smart struts are still perfect looking and I race my car around a track. I'm also redoing all the poly bushing on my front a-arms this winter. They look OK, but they have have been beat on for 10-12 years also.
Rear heim metal joints. I don't mind a minor deflection. true ability to generate high speed turning ability is the tires and alignment. My rear 335/35/17 Kumhos really hold the road
Old Oct 22, 2009 | 10:07 AM
Wrencher's Avatar
Wrencher
I'm with George on this, you have bigger problems than just that bushing. Mine have been in service for 10 years of hard driving with zero problems.
Hans
Old Oct 22, 2009 | 10:15 AM
texbeasr3's Avatar
texbeasr3
My differential yokes have end-play and the passenger side has excessive end-play. I will plan on getting the differential fixed.
Thanks to all for your input.
Ted
Old Oct 22, 2009 | 10:25 AM
Mike Ward's Avatar
Mike Ward
Ted
Just so you don't go on a wild goose chase, end play in the yokes (no matter how bad it is) has NO effect on strut rod geometry and has not contributed to the deterioration of the present bushings.
If you cannot achieve normal camber with the strut rods, that's another matter.
Old Oct 22, 2009 | 02:54 PM
texbeasr3's Avatar
texbeasr3
Mike,
I did notice the tire wear on the inner side, confirming the camber was not set correctly. I do know the adjustable strut was as twisted as tight as possble, as this was done at the alignment shop.
What else would you recommend I look at, if the yoke wear is not an issue?
Old Oct 22, 2009 | 03:15 PM
Mike Ward's Avatar
Mike Ward
Mike,
If you are in a roundabout way saying that your camber was/is not within spec and that it cannot be adjusted, the yokes are a strong contributor.
I was saying above that bad camber will not cause strut rod bushings to fail.
Old Oct 22, 2009 | 05:23 PM
texbeasr3's Avatar
texbeasr3
Mike,
Thanks for your reply...I will continue to work the yokes.
Ted
Old Oct 22, 2009 | 05:39 PM
SIXFOOTER's Avatar
SIXFOOTER
Those adjustable struts have an inner and outter end, are you sure you got them in correctly?
Old Oct 22, 2009 | 06:11 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Few listen, but while poly is fine for control arm and anti-roll bar bushings, as mentioned above it isn't best suited to applications which move in 3D by design, such as is the case with rear camber struts. Yes, other issues may cause camber issues, but I'd suggest going back to fresh rubber or stepping up to heim-jointed struts in any event for the long haul.
TSW
To Adjustable Strut with Poly Bushing Failure
