draw on battery
Old Oct 21, 2009 | 05:49 PM
vett 68's Avatar
vett 68
Default draw on battery
i have a bad draw on my battery i pulled all fuses and in 8hrs the battery was about dead i'm running a msd with a 6al everything else is stock it also has mew key switch & wiper is out but battery will die with all fuses out i don't know what to do thanks pete
Old Oct 21, 2009 | 07:09 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Completely remove the battery and see if it still dies.
Old Oct 21, 2009 | 07:18 PM
bluthundr's Avatar
bluthundr
Do you have anything wired in that does not go to the fuse block? To the starter or alt lug?
Old Oct 21, 2009 | 07:40 PM
7T1vette's Avatar
7T1vette
Electric fans on your car? Not tied in to ignition switch? Main power wire (+12 v) from battery has insulation wearing through somewhere? Error in wiring up the MSD box? Or, the most obvious reason....the battery is 'shot' and can't hold a charge?
Old Oct 22, 2009 | 06:50 AM
FB007's Avatar
FB007
Try disconnecting the alternator while it sits.
Old Oct 22, 2009 | 07:42 AM
avner's Avatar
avner
Try to turn the wiper switch under the steering column to the other position.
Avner
Old Oct 22, 2009 | 11:40 AM
DaJesterMan's Avatar
DaJesterMan
if your alternator is bad, it will draw current and kill your battery over time. you can take it into autozone and have them check it for free if you think it might be the case.
Old Oct 22, 2009 | 05:17 PM
Dantana's Avatar
Dantana
I had this proble, 6AL box was bad and pulling current somehow. At least I assuem that's what it was. I sent the box to MSD and for $85 I got it fixed up and no more battery problems for the last 2 years.
I also bought a battery charger...
Old Oct 22, 2009 | 05:51 PM
vett 68's Avatar
vett 68
Default thanks
thanks for all your help already checked battery not that but will check the rest thanks again pete
Old Oct 22, 2009 | 05:55 PM
vett 68's Avatar
vett 68
what is the other switch under dash ,i have wiper unhocked know still have drew pete
Old Oct 23, 2009 | 03:01 AM
avner's Avatar
avner
This one:
http://cgi.ebay.com/ebaymotors/1968-...Q5fAccessories
Old Oct 23, 2009 | 09:09 AM
gingerbreadman1977's Avatar
gingerbreadman1977
alternator is common like most have said. also trace your positive power wire from battery all the way along. if the red insulation has worn through or melted and the wire is touching your chassis,motor etc etc then your battery will drain very quick.
To draw on battery
