Bell housing question?
My question is, is there a way to repair this like welding or something or would that make it to weak. I have a 68 project with a 327 could I use the bell housing off the 327 on a 350?
Just clean the part thoroughly before you give it to the shop, so you will not have to pay for it. ( Inside + outside ).
Any remaining oil, paint or deposits near the welding zone can reduce the welding quality ( it makes microscopic bubbles including foreign materials ).
If you want your old part to look like a new one, the welding can be grinded before painting.
As your bell housing is not yet broken, the flat surfaces are probably not distorded, so they won't require milling.
But they should be checked after welding. A good shop will check it for you. Your welded part will be as strong as a new one.
In my country, this kind of job would cost you about $50 ( € 35 ), if you already did the cleaning work ( doesn't include any milling job ). In any case, this is what I would ask you for doing it...
