Correct carb gasket - help please
Old Nov 1, 2009 | 08:49 PM
spinadog's Avatar
spinadog
Default Correct carb gasket - help please
I have looked through the AIM, service manual, etc. for my 1970 454 4-speed (no EEC) to find the correct carb gasket and come up with conflicting results. When I had the carb rebuilt, the shop gave me a thin stainless steel heat shield plus a thin gasket. Both have the four holes and 'smiley face'. I also have the original GM oversize heat shield too.
Now, the AIM shows the carb being mounted with an 'open style' gasket. Now I am confused. The car ran OK with the ones I got from the speed shop (installed thus: GM heat shield, carb gasket, stainless shield) but this seems incorrect. The GM shield is an open style, so the gaskets had nothing to compress on.
Can anyone point me in the right direction? Also the install order would be very helpful. I suspect it's simply GM heat shield, gasket (open type), then carb.
Any help is most welcome. Cheers, S.
Old Nov 1, 2009 | 08:55 PM
TimAT's Avatar
TimAT
What does the intake look like? 4 holes and the smiley? just 4 holes? Open large at the rear like a Q-jet? Holley?
There should be a gasket between the manifold and the heat shield.
Old Nov 1, 2009 | 09:09 PM
spinadog's Avatar
spinadog
Tim, it's the standard intake manifold for a Q-jet (duh - should have mentioned that in my OP), so that's just the four holes, secondaries being larger and the pattern 'splayed'.
Here's a pic of the intake:
Here's the carb before restoration:
Here's what it looked like before I removed it (note - the EEC is not connected and has now been removed. The carb was a replacement sometime in the car's life and is NOT an EEC either):
So, should there be 2 gaskets to 'sandwich' the heat shield? Looking at the photos I answered one of my own questions re: gasket to intake.
Thanks for helping.
Old Nov 1, 2009 | 09:14 PM
TimAT's Avatar
TimAT
That makes it way better. That intake uses an open gasket that's about 1/4" thick and has a phenolic "button" at each stud. Check the length of the studs to be sure! You can put that on the intake, then your heat shield, then a thin paper gasket. Or the other way. I've got that shield under a Demon carb- just 2 thin gaskets with the aluminum sandwiched between.
Old Nov 1, 2009 | 09:17 PM
spinadog's Avatar
spinadog
Excellent. That makes complete sense.
Now, to track down the gaskets! Kragen has at least one fel-pro. Just gotta find the thin one.
Cheers - appreciate it.
Old Nov 1, 2009 | 09:20 PM
TimAT's Avatar
TimAT
No problem. You can buy me a beer next time I get to SoCal!!.
j/k
Tim
Old Nov 1, 2009 | 09:28 PM
spinadog's Avatar
spinadog
You're on!
As long as you can understand an Aussie accent - no problem!
Old Nov 1, 2009 | 09:35 PM
Peterbuilt's Avatar
Peterbuilt
Default Here's some part numbers.
Bottom gasket----------------Felpro 60043-----NAPA # (With foward grove)
Middle gasket (or use yours)---Felpro 60731-----NARA # (Stainless steel)
Top gasket (4 hole no grove ) Mr. Gasket 4256G
Old Nov 1, 2009 | 09:38 PM
spinadog's Avatar
spinadog
Pete - genius. Thanks!
Old Nov 9, 2009 | 09:39 PM
spinadog's Avatar
spinadog
UPDATE: Two Fel-Pro gaskets and $3 later, I solved one of the main sources of vacuum leaks.
So, it's open style all the way.
Tim - if you do make it down here and I am around, I'll gladly buy you a few beers, mate!
Cheers
Simon.
To Correct carb gasket - help please
