Another cam question
Old Nov 5, 2009 | 08:22 AM
RushThruLife's Avatar
RushThruLife
Default Another cam question
Does a carburated engine use a different type cam than one that would be used in an EFI engine? Given otherwise the same engine components.
Old Nov 5, 2009 | 08:58 AM
Gordonm's Avatar
Gordonm
Yes and no. Hows that for an answer. Most FI engines will run a wider LSA than a carbed engine. Not to say it won't run OK but a lot depends on duration and overlap. I am running a big solid flat tappet 252/260 @ .050 and it ran great with a carb. Changed over to FI and it runs good but the cruise and idle are tough. The O2 sensors did not like the big duration and long overlap, so I bought a new cam more suited to FI. Wider LSA and shorter duration but a higher lift, also solid roller from a solid flat tappet. Hoping to not give up and high end HP but make it more driveable.
Old Nov 5, 2009 | 02:06 PM
Matt Gruber's Avatar
Matt Gruber
Gordon
Does your EFI use IR, a dual plane, or a single plane?
I can't imagine IR not liking a bigger cam.
OTOH a single plane
Old Nov 5, 2009 | 02:57 PM
Gordonm's Avatar
Gordonm
The big cam at WOT is not a problem. It is cruising down the road with an OD transmission. There is so much overlap at 2000 or so rpm that the exhaust gets some raw fuel in it. This tells the O2 sensor hey we are running rich lean tha tsucker out. So I get a lean misfire at cruise rpm. WOT it just screams and has a ton of power. I'm hoping for a little more midrange torque also. To fool the system I have unplugged the O2 sensor and upped the fuel pressure. The lean misfire stopped but it is running somewhat rich at lower rpms. It is a port fuel system with a single plane intake. The cam I got is a 242/248 @ .050 so it is no slouch in the duration either.
Old Nov 5, 2009 | 03:01 PM
pr0zac's Avatar
pr0zac
i run a 107 lsa in my lt4.. that is just an old issue cause people didn't know how to tune them.
Old Nov 5, 2009 | 03:22 PM
Matt Gruber
Gordon
if it was my car, i'd make it into a dual plane EFI, fully separated. (if i couldn't afford 8 runners).
TRUE Dual plane makes a world of difference. My powerband went from 2400 and up, down all the way to 1000 when i fully separated my dual plane. EFI should have a similar improvement.(i'm no expert on EFI, but i can't imagine why u'd want a single plane)
Old Nov 5, 2009 | 03:59 PM
RushThruLife
So if I understand this... a cam made for a EFI system will probably work fine in a carbed engine but a cam made for a carbed engine may not run well in a EFI engine. This could also account for my engine running really lean.
Old Nov 5, 2009 | 04:12 PM
Gordonm's Avatar
Gordonm
What are your cam specs.
Matt, EFI and carbs are worlds apart. There could be volumes written on this.
prOzac Explain then.
Old Nov 5, 2009 | 04:23 PM
RushThruLife
comp cam ex 262 exteme energy,462 intake lift 469 exhaust lift
Old Nov 5, 2009 | 04:28 PM
Gordonm's Avatar
Gordonm
That is a very mild cam and should work pretty well in a carb or EFI situation. There is going to be very little overlap with that cam.
If you are running a carb with that cam it should provide good low end to mid range torque.
Old Nov 5, 2009 | 04:43 PM
Matt Gruber
Gordon
u need a Hillborn EFI. Have u researched individual runner EFI? They cost a lot.
Me,being cheap, I would buy the very best dual plane, and get most of the benefits of the Hillborn at a fraction of the $$$$, by converting it to EFI.
Single plane sucks on the street w/big cams and OD, 9 times out of 10. EFI or carb is going to suck at low revs. Overlap is to blame w/big cams. Hillborne or a dual plane can cure that. Dual plane is the best value. I don't even know if they sell it, so if they don't i'd make it.
Old Nov 5, 2009 | 05:20 PM
RushThruLife
Thanks Gordonm. Before I removed the EFI, it provided a nice little lobe at idle. Now to put the right carb back on it.
Old Nov 5, 2009 | 08:42 PM
pr0zac's Avatar
pr0zac
define what constitutes a carb cam
Old Nov 5, 2009 | 09:06 PM
Gordonm's Avatar
Gordonm
Not saying anything defines a carb cam. Just saying most fuel injection runs better with a wider LSA than a tight one. There are way to many variables in any engine to say which cam is best for any given application.
Old Nov 5, 2009 | 11:26 PM
pr0zac's Avatar
pr0zac
you can run any cam with fuel injection.. its just harder to tune the idle. btw my cam spec are 245/253 .612/.612 on a 107lsa in a 12.3:1 385 and i run pump gas and use my stock pcm.
Old Nov 6, 2009 | 09:38 AM
RushThruLife
The reason I asked the question was because I called Comp cams for some specs on my cam. I need to order my dist (Davis Unified) and they require that info to provide me with the best one suited to my engine needs. Comp Cams has 2 xe 262cams. one for a carb and one for EFI.
Old Nov 6, 2009 | 01:47 PM
Gordonm's Avatar
Gordonm
Once again I will bring up LSA on the cam. The standard one is ground on a 110 LSA the computer controlled or the one for fuel injection is ground on a 114 LSA. The duration and lift are almost identical. The wider LSA is more computer and fuel injection friendly. Most of the mild FI cams you are talking about can be used with a stock computer system.
Old Nov 7, 2009 | 08:49 PM
Ironcross's Avatar
Ironcross
You should be able to use the cams interchangeably, GM has been doing it for years....its that FI`s distribute the fuel better...and actually more economical until you start building a more radical all out racing engine....
To Another cam question
