starting problems
Old Nov 6, 2009 | 10:09 AM
NMT1957's Avatar
NMT1957
Default starting problems
What could be my problem when i turn the key and nothing and another time I'll start to crank.Any ignition switch concerns. How about this lockout thing is it there on a 70 454 auto?thanks for the ideas.
Old Nov 6, 2009 | 10:21 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
There is a safety switch on both manual and auto trans '70 Corvettes. I have a manual, and I can't turn over the starter unless the clutch is depressed. On mine, I belive it is called a "neutral safety switch", but that might be the name for the auto version.
Old Nov 6, 2009 | 11:05 AM
...Roger...'s Avatar
...Roger...
You need to find out if when you turn the key to "start" is the S term on the solenoid getting power. Until you find that out you will be guessing.
Old Nov 6, 2009 | 01:39 PM
pacrimmat's Avatar
pacrimmat
Its more than likely your connection at the starter motor. Easiest to check first.
Old Nov 6, 2009 | 08:32 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Do a forum search.
Here's the same problem from yesterdays link: http://forums.corvetteforum.com/c3-t...g-problem.html
My answer is the same - flip the disk inside the solenoid cover.
Good luck,
cardo0
Old Nov 7, 2009 | 09:33 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Assuming you have checked all battery cables,
either your iginition switch on top of the column needs adjusting,
or your netuel safety switch is not working correctly,
or Cardo is righto flip the copper disk in the starter solenoid, or replace, it.
69VETT
Old Nov 7, 2009 | 09:39 AM
...Roger...
He got it fixed. He had a ford type remote mount solenoid and the small terminals were mis marked. Once he got that straightened out the engine turns over.
To starting problems
