Temp sending unit problem
Old Nov 6, 2009 | 10:47 PM
ocstanley's Avatar
ocstanley
Default Temp sending unit problem
Need some help before I go crazy. Just installed a new temp sending unit in my '72. Prior to installing it I placed it in a cup of boiling water and it worked as expected - off by just a few degrees. Anyway, I installed it and it now it doesn't work. Since I know the sending unit and gauge are working, I'm thinking I have some sort of grounding problem involving the engine block. I am not using any tape on the threads. Is it possible that the block's threads could be corroded and keeping the sending unit from grounding properly? Suggestions? Thanks.
Old Nov 6, 2009 | 11:02 PM
dannyman's Avatar
dannyman
Guage and sender both work; time to check the wiring. If not using teflon tape you are assured of a good contact through threads. Look for a chaffed or broken wire.
Old Nov 7, 2009 | 12:56 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
ocstanley
I'm curious how you know it was only off a few degrees in boiling water? This makes no difference right now since the gauge is not working. I've posted a scale on here in the past about what the required ohm's per the dash unit should be and was just wondering if you used it.
If you pull off the wire to the sending unit and touch it to the engine the dash unit should peg hot. If you remove the wire from the sending unit the dash unit should go to the cold position.
If these test work, then your dash unit and wiring are fine and the problem is the sending unit. If they do not work, then you have an issue in the car wiring.
Are the other gauges in the dash still working.
The sending units are cut in N.P.T. threads and they are tapered. Corrosion in the block threads should not play any roll in this since the tighter you turn the sending unit the more the threads dig in!
Willcox Inc.
Old Nov 7, 2009 | 06:42 PM
ocstanley's Avatar
ocstanley
Now I'm not sure what I have. When the engine is on and running for about 10 minutes, the temp gauge needle just clears the 100 degree marker. I placed a 75 ohm resistor across the wire leading to the temp sender unit and grounded it, hoping to get a reading of about 220 degrees. Result: The temp gauge read approximately 125 degrees.
Any ideas/suggestions? Thanks
Old Nov 7, 2009 | 06:44 PM
Petes73's Avatar
Petes73
Did you use teflon tape on the threads. If you did you have a bad ground as stated above and you will never get it to read correctly.
Old Nov 7, 2009 | 06:56 PM
ocstanley's Avatar
ocstanley
No teflon tape - still pulling out my hair.....
Old Nov 7, 2009 | 07:27 PM
...Roger...'s Avatar
...Roger...
Sounds like the resistor across the back of the gauge is missing or bad.
Old Nov 7, 2009 | 08:26 PM
0Willcox Corvette
Former Vendor
Roger is correct! Pull the dash unit out of the car and test the resistor. When the resistor is shot, about the highest reading you can get out of the gauge is 1/4 of it's full output.
This sure sounds like the gauge resistor is shot to me.
You have movement and response in the dash unit which tells me you have power to the gauge and a good ground.
You have signal making it to the gauge since you have movement. This all but eliminates everything else it could be. If you need this fixed you can pick up a resistor from your local electronics store.
Willcox
Old Nov 7, 2009 | 08:41 PM
...Roger...
Willcox
Ernie do they have some kind of high heat resistor ?
Old Nov 8, 2009 | 09:49 AM
ocstanley's Avatar
ocstanley
Thanks guys! I'll check the resistor and get back to you. Any idea as to the resistance I should be getting across the resistor? Thanks.
Old Nov 8, 2009 | 11:02 PM
0Willcox Corvette
Former Vendor
On your car.. around 90 ohms off the gauge... You will either get a reading or you'll get open circuit... If it's good, post again... If not well.. post again and I'll tell you how to make one...
Willcox
To Temp sending unit problem
