Dash Lights
Old Nov 9, 2009 | 01:26 PM
sharky69's Avatar
sharky69
Default Dash Lights
Just found out the hardway that my dash lights wont light up when I turn the headlights on....
What should i check other than fuses?
Old Nov 9, 2009 | 03:26 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Check the headlight switch if the fuse is OK.
Old Nov 9, 2009 | 03:53 PM
...Roger...'s Avatar
...Roger...
Also don't be fooled by a good looking fuse,check both sides of the fuse and the fuse contacts using a test light. A fuse can break inside and it can also not be making connection with the contacts.Check the INST fuse with the headlight switch pulled out.
Old Nov 9, 2009 | 03:57 PM
sharky69's Avatar
sharky69
Thanks for the help!
To Dash Lights
