Problem Starting 80'
Old Nov 10, 2009 | 06:09 PM
Copacetic's Avatar
Copacetic
Default Problem Starting 80'
I have a 1980 5.7L. So when i go to start i just get a few slow cranks and then it stops and i hear a buzz coming from around the starter area. If i leave the car for a day the battery dies and i have to use jumper cables.
Old Nov 10, 2009 | 06:25 PM
mandingo214's Avatar
mandingo214
Sounds like the battery is dead/dying. How old is the battery? Is the buzz kind of a clicking, like the starter is not engaging?
Old Nov 10, 2009 | 06:39 PM
Duane4238's Avatar
Duane4238
Try a new or donor battery just to see if that is it. Sure sounds like it to me.
Old Nov 10, 2009 | 08:15 PM
Goody's Avatar
Goody
Try a fully charged battery. A low volt battery will make the solenoid do that buzz thing or may even get it to clank against the flywheel/flexplate but not have the power to turn the engine over.
If you are saying that with a new charged battery the car can only sit a few days before the battery is completely drained then you have an electrical issue somewhere.
Old Nov 10, 2009 | 08:43 PM
Project80's Avatar
Project80
After you jump start the car, it needs to be driven for awhile to charge the battery back up or use a trickle charger. Many members who don't put a lot of miles on their vehicles use battery tenders to keep the battery charged.
Also, use a voltmeter (VOM) to check the battery output, it should be at least 1 volt over battery voltage. This is a fast check, it only checks voltage, not amperage.
As already mentioned, the battery could have seen better days and just won't hold a charge. How old is it?
I am thinking that you already cleaned and reinstalled the cable connections so it couldn't be that, right?
To Problem Starting 80'
