Measuring pushrod length
Here's a Holley link off of AFR's website .... with instructions.
My question is this: Are you to rotate the engine by hand, or put the rocker cover back on loosely and crank it with the starter?
My stroker has 20K on it, and it's still quite hard to crank over by hand using the balancer bolt. Guess you pull the plugs out to make it easier? Seems if you use the starter to crank it over faster, the oil would wash off the magic marker from the top of the valve.
Thoughts appreciated
My engine runs GREAT with the heads (I have almost 1500 miles since installing 'em) but I have a LOT of valve noise. I've re-lashed them three times and they always sound the same. So I figure it can't hurt me to check pushrod length and make sure it's correct. I'm using a Crane flat-tappet hydraulic cam.
Did you pull all your spark plugs?
In the past I have used an adjustable pushrod with checker springs on both an intake and an exhaust valve. Turned the motor over by hand. Adjusting the pushrod length to achieve the smallest/shortest witness mark in the felt marker dye. I would start with the oem length. Based on wether it is centered on the valve stem or leaning to the intake manifold or the heads will help you determine if it needs to be longer or shorter.
I have never heard of actually running the engine.
I'm still driving it - haven't taken a wrench to it since putting the heads on. When I put the heads on, I used chromemoly standard length pushrods.
It's a Crane flat tappet hydraulic cam and I'm running Crane 1.6 roller rockers. None of that stuff has changed since building the engine a few years back. All I did recently was replace cast heads with AFR Aluminum ones.
At zero lash, I got lots of valve noise, so I rechecked them all. Same noise .... so I gave 'em all 1/2 turn past zero. Didn't affect the noise at all. Last try was 3/4 turn past zero lash.
I am coming to the realization that it's just going to be a lot noisier with the aluminum heads on it. I've built a LOT of engines in my years but the only ones I ever put aluminum heads on, were OEM Japanese stuff. All my previous small block Chevy motors were long before I could afford a set of AFR heads.
My Brother is the automotive engineer of the family and he tells me the noise is normal. He claims that the aluminum heads are going to reflect at least 50 percent more noise than the cast iron ones did. And man, it sure sounds like it!
But back to measuring the pushrods: I want to make sure they are the right length as I don't want make oil-pushers out of expensive heads. I've heard horror stories about valve guides getting all screwed up because of incorrect geometry and I want to get this detail nailed down perfect.
So when I color the tops of the valves and reassemble the roller rocker, do I crank it over by hand? How many cylinders do you check?
It works very well. I also checked with the felt tip marker after installing the pushrods and it was right on.
