E Brake Upgrades?
Old Nov 11, 2009 | 12:20 PM
Taijutsu's Avatar
Taijutsu
Default E Brake Upgrades?
Like most of us my E brake is useless. I did the new cables and easy stuff, but that didn't work. I'm going to replace the brake shoes and the brake lever between the seats.
Do I have any options on the brake lever? Is there something better, cooler or cheaper?
Once I dig into this project, I'm stuck for the duration.
I don't want to haul it to the shop w/tow truck because I can't finish!
What would be a "Worst Case" and what would I need to fix it?
I have pry bars and a small propane torch, what else might I need?
I remember something about heating and possibly breaking something inside. Will a big chisel do the job?
I want to do this right the first time, but that seldom happens. lol
I remember a forum member needing the new brake shoes arched or fitted to the drum to get any real braking. Is this necessary?
This is looking like a weekend project, I'd like to finish by Sun! lol
Any help or advice before I start making a mess? TIA
R
Old Nov 11, 2009 | 01:21 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
The only thing I know of is to NOT do what I did - use Stainless brake shoes. They flex more than good steel does and hinder an already poorly working brake. So then - make sure your brake cable is tight and fastened to the frame where it's supposed to be. Make sure your E-brake shoes are adjusted properly and they will work.
If it's a four speed, make sure you leave it in low gear or reverse when parked. If it's an automatic make sure your shift linkage is properly adjusted so it goes all the way into park and engages the parking pawl.
Old Nov 11, 2009 | 01:29 PM
stevelischynsky's Avatar
stevelischynsky
First I've heard of the stainless flexiing more.
Steve L
73 coupe since new
Old Nov 11, 2009 | 05:03 PM
Taijutsu's Avatar
Taijutsu
Thanks for the SS info. I'm sure there are some horror stories out there.
I wonder if a wheel puller might be a good thing.
What about the crappy E brake lever. Is there anything better that I can use? I was not impressed w/stk lever!
I will let this run for awhile before I order parts.
R
Old Nov 11, 2009 | 05:33 PM
Peterbuilt's Avatar
Peterbuilt
Default Start at #22.
Here's a how to http://www.corvettemagazine.com/tech...e-rebuild.html
You might start by trying to adjust at the wheels than adjust the cables. It's rare that the brake shoes are worn out, most likely rusted in place.
Old Nov 11, 2009 | 05:44 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
It might be giving the C3 park brake system too much credit to consider it as a bona fide "E brake", and I'm certainly not the only one who has slipped the trans (manual) into 3rd or 4th and stalled the engine in order to pass an inspection.
These might help...
Old Nov 12, 2009 | 09:03 AM
carbster09's Avatar
carbster09
Default Parking brake .... not E!
The E brakes suck. I would really like to add a small caliper like Wilwood makes and do away with the mess behind the drum. Then agian mine do work ... as a parking brake. they keep the car where it should be and no more.
Old Nov 12, 2009 | 09:35 AM
bashcraft's Avatar
bashcraft
Mine works perfectly with stainless shoes.
Old Nov 12, 2009 | 09:54 AM
stevelischynsky
When my car was brand new, the E-brake hardly held in the forward direction but it held a lot better in the reverse direction.
When I parked it on a hill of about 5 degrees, I would have to pull the handle with both hands to keep the car in place (manual tranny in neutral) in the forward direction, but repeating in the reverse direction it was no problem.
This was right out of the factory. The E-brake was basically useless. It only gave me grief years later, when after years of storage, the lining swelled and froze the rear wheels solid. I had to use a gear puller to pull off the disk.
Steve L
73 coupe since new
Old Nov 12, 2009 | 10:10 AM
CCrane65's Avatar
CCrane65
But you really need to take the time to adjust them properly. That means taking the car out and driving it and applying the parking brake at different speeds by holding the button on the handle then releasing in order to burnish them in.
Then let them cool off and re-adjust each side. If you follow the instructions in the service manual you should be ok.
BTW, stainless is better than common steel because of the rust problem.
Also, Chevy did not call them emergency brakes, they are parking brakes. Some of the older handles (C2) even had the words parking brake on them.
If I had to rely on these things in an emergency I'd start praying for a miracle.
cc
Old Nov 12, 2009 | 08:51 PM
TJP440's Avatar
TJP440
properly adjusted they work fine in my experience.
Old Nov 12, 2009 | 09:14 PM
Gordonm's Avatar
Gordonm
Mine works very well and I have SS shoes on mine. Been working good for the last 10 years.
Old Nov 12, 2009 | 09:31 PM
Duane4238's Avatar
Duane4238
In my experience, the stainless shoes are absolutely awesome. Once you get your parking brake system back in order, the trick to keeping it working correctly is to use it. Every time you turn the car off, you pull the handle after you remove the ignition key. That's the only way you'll keep it operating properly. My "parking brake" has never given me any problems. And by the way, if you talk to any veteran owners who've been driving more than 40 years, you'll find that it is a "parking brake" and not an e-brake. They were never meant to stop you in an emergency. Back in the day when most cars had manual trannies, you had to have some way to keep them in one place when turned off. A lot of man. trans. wouldn't hold or would pop out of gear when parked, so you used the parking brake. By the way, the cable in my first car was rusted away, so I carried a "parking brick" in the glove box for daily use.
Old Nov 13, 2009 | 07:44 AM
Ganey's Avatar
Ganey
Originally Posted by Duane4238
Once you get your parking brake system back in order, the trick to keeping it working correctly is to use it. ...
If the e-brake is working, downshift through the gears & use the e-brake at end. Worked for me after a bunch of 0-100-0 runs.
Old Nov 19, 2009 | 01:40 AM
gtc131's Avatar
gtc131
Do you have more info on that? Sounds great.
Update: I've just read elsewhere that Wilwood no longer supplies them.
Old Nov 19, 2009 | 04:07 PM
gtc131's Avatar
gtc131
Here's a pinion mounted solution for 63-79 from The Streetrod Manufacturing Co:
http://tsmmfg.com/Pinion_Mounted_Parking_Brakes.htm
Anybody have feedback on/experience of this product?
Old Nov 19, 2009 | 04:45 PM
Gordonm's Avatar
Gordonm
There is no room at the pinion of a Vette for this. Just set up the stock system correctly. It does work and if setup right will work well.
To E Brake Upgrades?
Old Nov 19, 2009 | 05:11 PM
wcsinx's Avatar
wcsinx
They list kits for Corvettes. But they have different part #'s for driver v/s passenger side and ubolt v/s straps. That would seem to indicate the intended mounting is the stub axles and not the pinion.
Old Nov 19, 2009 | 08:18 PM
gtc131's Avatar
gtc131
My parking brakes are set up correctly and they're barely useful. I have a 454 manual and I need a good brake for hill starts. I'm looking at this pinion design as a serious solution.
Old Nov 20, 2009 | 08:50 AM
L88's Avatar
L88
I took a linear actuator (200lb pull) , made a bracket, designed a little circuit & it comes on when I turn off the key & releases when the key is turned on. Took out the parking break lever. So with the key turned off this car will not roll. Was thinking of installing a override swich , but never did
Alan
