I took a linear actuator (200lb pull) , made a bracket, designed a little circuit & it comes on when I turn off the key & releases when the key is turned on. Took out the parking break lever. So with the key turned off this car will not roll. Was thinking of installing a override swich , but never did
Alan
That's a novel approach ... but it depends on battery, and lack of brake lever would be a problem for me at registration time.
What interests me about your solution is that you seem to have improved the brake performance by increasing the pull on the cable. I had formed the impression that the flaw in the brake design was insufficient leverage at the shoes -- meaning the shoes can't press against the drums with sufficient force. I didn't think an increase in tension would overcome that basic flaw.
They due hold better this way & I don't drive away anymore with the break on which I have done many times. A bypass switch would work to get it through inspection,but I don't worry about that since getting antique plates. This is a simple solution to a problem on most C-3's
Alan
Addressing the SS issue. Years ago some of the SS shoes were not made right and wouldn't contact the drum correctly so less the than the entire face of the shoe was being used. The shoes would flex and didn't give a solid feel when pulling on the lever. Also some of the SS mechanism was too thick and would not go through the backing plate. I stopped using the SS shoes back then and even after the problems were corrected didn't use them because I didn't see a real advantage.
