Issues swapping my speedometer
Old Nov 14, 2009 | 09:34 AM
larryg3's Avatar
larryg3
Default Issues swapping my speedometer
I am in the process of replacing the stock 85 MPH speedometer (81 vette) with a 140 MPH speedometer out of a 78-79 vette. i took the tach speedometer cluster apart only to find a set of wires going to the back of the speedometer. i looked in the service manual that i have and discovered that they are actually the VSS (vehicle speed sensor). the question i have is the following, i want to do the speedo swap but i do not want to disable the lock up converter in the trans. is this possible and if so how? is there and aftermarket VSS that can be mounted in some other part?
Old Nov 14, 2009 | 02:22 PM
doctorgene's Avatar
doctorgene
Yes Sir: You can have your Speedometer refaced to either 140 or 160 an reinstall it. But the lock up converter can be hook up with a switch at your finger tips. The 81 & 82 had the first computers. Some one I'm sure has traced the wiring out on one of these. I'm going to listen in on this Thread. Have a great day. Gene
Old Nov 14, 2009 | 03:28 PM
...Roger...'s Avatar
...Roger...
Where is Willcox ?
Old Nov 15, 2009 | 12:57 AM
larryg3's Avatar
larryg3
Thanks Gene. looks like i will have to sell the speedo that i just bought.
Old Nov 15, 2009 | 01:50 AM
86atc250r's Avatar
86atc250r
I believe the stock vss is a 2000 PPM square wave unit.
You can get an inline type that threads onto the transmission speedo output, then the cable threads into it for $50 or so. I used one of these in a TPI conversion I did years ago - worked great. I believe the application I used was a Chrysler of some sort. I ended up purchasing online from a speedo shop.
I believe older Taxi's also used this type of sensor for their meters.
Old Nov 15, 2009 | 10:39 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Larry,
Send both to me and I'll swap the face for you and calibrate your old speedo to the new face.
Willcox
Old Nov 15, 2009 | 09:39 PM
larryg3's Avatar
larryg3
thanks guys for the advice. I will take willcox up on the offer.
Willcox please send me instructions for the shipping and i will send them both to you.
Old Nov 16, 2009 | 07:56 PM
0Willcox Corvette
Former Vendor
Willcox Inc. c/o Service
123 E. Maple Street
Jeffersonville, Indiana 47130.
Willcox
Old Nov 18, 2009 | 11:22 PM
larryg3's Avatar
larryg3
i will take the stock speedo out this week end and send out next monday thanks
Old Nov 18, 2009 | 11:30 PM
0Willcox Corvette
Former Vendor
I have instructions on my site if you need to see how the speedo comes out.
http://willcoxcorvette.com/repairand...lp.php?hID=146
Willcox
Old Nov 18, 2009 | 11:53 PM
larryg3's Avatar
larryg3
great thanks i am sure that will help just one question how do i disconnect the VSS from the speedo?
Old Nov 29, 2009 | 11:17 AM
larryg3's Avatar
larryg3
Wilcox, i just wanted to say thanks. You guys did a great job. it took me longer to get the speedo out of the box than it did to install it. I was happy it was a nice day so i was able to take the car out and test the speedo. It is spot on. thanks again. Great price great service cannot ask for more.
here is a pic
Old Dec 5, 2009 | 09:05 PM
0Willcox Corvette
Former Vendor
Thanks Larry...
Glad you like it.. Pretty sure Vic calibrated the other head to match the other face too!
So now you have one you can sell.
Willcox
Old Dec 5, 2009 | 09:29 PM
larryg3's Avatar
larryg3
yes he did!!! again thanks a lot!! You guys really knock it out of the park!!!
To Issues swapping my speedometer
