69 Distributor
Old Nov 14, 2009 | 09:50 AM
racinmann's Avatar
racinmann
Default 69 Distributor
I'm not sure how to go about this... I either change the distriutor or the tach on my 69. I'm not sure of the cost for the gauge or finding a distb. All input is welcomed.... thank you.
Old Nov 14, 2009 | 09:57 AM
Mike Ward's Avatar
Mike Ward
OK, what problem are you trying to fix?
Old Nov 14, 2009 | 10:18 AM
...Roger...'s Avatar
...Roger...
I put a ZZ4 in a 69 and I kept the HEI and had the 69 tach converted to electronic.
Old Nov 14, 2009 | 02:42 PM
DZRick's Avatar
DZRick
I went the other way and bought a tach drive distributor keeping the original gauge. I did keep the original tach though.
Old Nov 14, 2009 | 03:08 PM
...Roger...
Just to clarify,when the gauge was converted the original tach face was used so you cant tell by looking.
Old Nov 14, 2009 | 03:47 PM
7T1vette's Avatar
7T1vette
I'm a little surprised that Chevy Parts didn't offer an option for a tach-drive HEI distributor on the engine you purchased.
Old Nov 14, 2009 | 03:49 PM
DZRick's Avatar
DZRick
Works for me Roger, I just figured it would be easier for someone if they ever wanted to return to the stock, much easier to swap out the distributor than messing with the gauges IMO.
Old Nov 14, 2009 | 03:58 PM
...Roger...
Your absolutely right it would be easier than removing the dash.
I think both ways have their advantages , I'm glad my customer stepped up to plate and made the choice.
Old Nov 14, 2009 | 04:01 PM
racinmann's Avatar
racinmann
auction # on E is .... 220502268201 ... shows a couple listings.... is this the easiest way to go and would there be anything else I'd have to do to the orig. tach???? Thanks...
Old Nov 14, 2009 | 04:02 PM
racinmann's Avatar
racinmann
By the way Roger.... how did you get so many stars under your name???? You must have been around a loooong time!!! Ha!!
Bo
Old Nov 14, 2009 | 05:57 PM
racinmann's Avatar
racinmann
I would like to also add that my dash is already out... the guy I bought it from just put in a Tilt/Tele column and I think I have to unbolt the brace to get it back in??? It looks like a project getting everything hooked up or I need a little monkey..... maybe...????
Old Nov 14, 2009 | 07:16 PM
69monzacpe's Avatar
69monzacpe
If you are talking about getting the dash back in, you have to undo the two bolts holding the steering column in that are located about where the bottom of the dash would be located. This allows the column to drop down some so you can get the dash in. Be careful so you don't break the part of the dash that sits on the column, or scratch the column. It's one of those PIA jobs on 'vettes that you will only want to have to do once.
And yes, a little monkey might help....
To 69 Distributor
