Help im locked out!
Old Nov 14, 2009 | 01:27 PM
74batmobile's Avatar
74batmobile
Default Help im locked out!
so heres the issue, i have been dynamatting my car for the passed week or so and last night i got home a little early from work to finish up. my passanger side door has been stuck for a while, the outside door handle are messed up so not a problem id fix that when i had a chance. and now my driver side door refuses to open. there is still presure when u push down but its like the locking is refusing to let go. AND im locked out of my car!
can anyone tell me how to open it. i tried for the life of me to press down and nothing....any advice would be greatly appriciated...id hate to bust open my window to get the door open!
thanks guys
Old Nov 14, 2009 | 01:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Dont break the glass what ever you do!
Is the door locked? Have you tried to put the key in and un-lock while pushing on the handle?
If all else fails, go thru the t-top weatherstrip to the t-top handles. If you can try to get the t-top handle down go from the inside and see if you can get it open.
Good Luck,
Willcox Inc.
Old Nov 14, 2009 | 01:49 PM
...Roger...'s Avatar
...Roger...
Sometimes just shooting WD in everywhere and working the handle and lock will loosen gunk and allow the linkage to move and unlock.
Old Nov 14, 2009 | 03:50 PM
7T1vette's Avatar
7T1vette
I would choose spray silicone [rather than WD-40], but either should work to loosen the binding lock mechanism enough to open it....ONE MORE TIME before you finally fix it.
Old Nov 14, 2009 | 05:12 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Make a solid fist and pound on the t-top right where the latches are. They should fall.
Old Nov 15, 2009 | 03:27 AM
74batmobile
i finally got in to the car, but for some reason it wont open from the inside. the latch is locked and wont open.
Old Nov 15, 2009 | 07:31 AM
...Roger...
If the lock lever is not 100% returned it won't open.
If the outside handle flap is not up 100% the lock lever cannot return 100%.
Its a safety thing and if the lock has a lot of wear you might have to replace it.
Here is a pic that has an arrow pointing to the lever that opens the door.
Old Nov 16, 2009 | 12:55 PM
74batmobile
anyway to open it? flat head screw driver or something?
Old Nov 16, 2009 | 01:23 PM
...Roger...
With a screwdriver push down on the lever that the arrow is pointing to and if the lock is fully off the latch should release.
To Help im locked out!
