side mirror sag
Old Nov 14, 2009 | 07:59 PM
BigDave11223344's Avatar
BigDave11223344
6th Gear
Default side mirror sag
Anyone know how to "tighten" up a drivers side review mirror? The mirror part keeps moving as I drive. Not sure how to tighten the ball / mirror joint.
Old Nov 14, 2009 | 09:11 PM
temvette72's Avatar
temvette72
You have to soak the mirror head in solvent overnight or longer to get the glass mirror to release from the metal frame. There is a metal strap that is riveted across the little ball on the stalk. You have to "tighten up" that strap across the ball. There is a thread sonmewhere on the forum with good pix of the process. I ended up buying a new mirror off Ebay because I broke the mirror due to my impatience! I hope you have better luck than I did!
Temvette72
Old Nov 14, 2009 | 09:38 PM
BigDave11223344
6th Gear
Thanks Temvette72. I will give that a try.
Dave
Old Nov 14, 2009 | 10:16 PM
Milest's Avatar
Milest
http://forums.corvetteforum.com/c3-t...-the-wind.html
To side mirror sag
