454 to 496
Old Nov 14, 2009 | 11:29 PM
NEILZVETTE's Avatar
NEILZVETTE
Default 454 to 496
What would be required to make this swap other than the stroker crank. I know on a 383 it takes special rods and pistions but Jegs shows that it calls for the same part # pistions and what I think is the same length conn rods for the 454. Am I missing something..this is in a 70 Vette.
Old Nov 14, 2009 | 11:41 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
The comp height on 454 pistons is 1/8" more than on 496 pistons using the same rod. Sounds like an error in their listing.
You can use the std factory 6.135 rods for a 496 build, but I would recommend the 6.385 rods in a 496.
Old Nov 15, 2009 | 12:32 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Using the longer rods makes things a lot easier because pistons are lighter. This makes balancing a lot easier.
JIM
Old Nov 15, 2009 | 01:49 PM
NEILZVETTE's Avatar
NEILZVETTE
Thanks for the info. I was confused myself when I read that.
To 454 to 496
