Plugs Recommended
Old Nov 17, 2009 | 05:08 PM
RushThruLife's Avatar
RushThruLife
Default Plugs Recommended
Need to purchase a good set of plugs for my 1980 L82.
A little modified. Has a Davis Unified HEI and Livewires. Any recommendations?
Old Nov 17, 2009 | 06:10 PM
Ironcross's Avatar
Ironcross
Should be the small tapered seat 'peanut' plug...AC R45TS
Old Nov 18, 2009 | 09:26 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Is there something wrong with the "stock" plugs?
No need for a colder plug. Stay with what the General sold it with - AC 44 or AC 45.
cardo0
Old Nov 18, 2009 | 10:07 PM
71coupe454's Avatar
71coupe454
I put a set of E3 spark plugs in my 454 the other day. They look cool, said to give 10hp, who knows, it runs good on the engine stand..lol
Old Nov 18, 2009 | 10:24 PM
babbah's Avatar
babbah
Try the NGK Iridium plugs - I have them in all my cars including my 67 BB and they are awesome.
http://www.ngksparkplugs.com/product...x.asp?mode=nml
Try em, you'll like em and they last and last!
Old Nov 19, 2009 | 02:43 PM
BKbroiler's Avatar
BKbroiler
cardo0
These work good for me (either type).
Old Nov 19, 2009 | 02:55 PM
TWINRAY's Avatar
TWINRAY
Been using the basic Autolights since the 70's with never a problem. Just get a corresponding match up from the recommended AC#.
Old Nov 19, 2009 | 03:41 PM
Mike Ward's Avatar
Mike Ward
Yup, gotta agree. They work just as well as the stock plugs and only cost 5 times as much!
Old Nov 19, 2009 | 10:21 PM
babbah's Avatar
babbah
Read on - http://sharedreviews.com/r/31547-ngk...plug-set-10-hp
Old Nov 20, 2009 | 09:11 AM
TWINRAY's Avatar
TWINRAY
99 bucks + S&H
but I'm a cheapskate anyway.
Old Nov 20, 2009 | 09:18 AM
Mike Ward's Avatar
Mike Ward
That's frighteningly bad science and misapplied logic. I will admit that I was wrong about one point. They're not 5 times the price, it's 8 times.
Old Nov 20, 2009 | 09:51 AM
Paul L's Avatar
Paul L
This plug works very well.
Old Nov 20, 2009 | 10:15 AM
zwede's Avatar
zwede
Most plugs work well in our engines. I stay away from plugs with screw on terminals (like Bosch) as the terminal has a bad habit of coming loose. I've tried NGK, Autolite, AC and Champion and all work fine, no difference as far as I can tell. I also stick to regular copper plugs. They are easy enough to change that the added cost of long life (platinum/iridium) is not worth it.
Old Nov 20, 2009 | 04:14 PM
RushThruLife
Went with what the General had in her to start with. The problem I`m running into now is header clearance. I have none. Accels were in the car. I suppose because they ere shorter, but only by about 1/4 inch. So I suppose I place a little heat resistant material between the header and the wire cap(where it touches). This only happens on number 3,5 and 6. I need a special tool to get in and tighten the plugs up. Any ideas? Cause a normal plug socket just ain`t gettin it.
Old Nov 20, 2009 | 05:57 PM
Ironcross's Avatar
Ironcross
I presume you have a SB engine...but it works with either engine, big or small....Next time try running your plug wires underneath like factory with the 90 drgree spark plug boots...similar to the Ram Horn manifolds......
Old Nov 20, 2009 | 07:49 PM
RushThruLife
As I stated in the original post the engine is a 1980 L82 SB. They are 90 degrees spark plug boots. The problem is my Hedman headers. Make the plugs hard to access without loosening the header bolts. I can get the boots on...its just hard to tighten the plugs themselves.
Old Nov 21, 2009 | 11:36 AM
babbah's Avatar
babbah
- I get them for $6 each online - $48 per set - It that 8 times the price of a ac delco set? I think NOT!!
To Plugs Recommended
