removing AC from my 76 C3 - help
Old Nov 17, 2009 | 11:10 PM
Iggycat2009's Avatar
Iggycat2009
Default removing AC from my 76 C3 - help
Pulling what's left of my air conditioning to include the AC wiring harness in my 76 C3. I will replace it with a non AC wiring harness and install an AC delete plate on the firewall. Is there anything I need to watch out for?
Thanks,
Mike
Old Nov 18, 2009 | 01:04 PM
BKbroiler's Avatar
BKbroiler
My 77 has headers on it and I had to remove the right header to get the AC accumulator vessel out. The evaporator came out easily after that - one bolt, at the bottom, inside the car however. If you have stock manifolds you shoud be OK. The AC Delete cover fits nicely.
Old Nov 18, 2009 | 04:28 PM
snoopykissedlucy's Avatar
snoopykissedlucy
AC delete plate? Who makes this?
I am doing the same thing and have a huge hole left over.
I was going to rivet a piece of steel but is the delete plate cosmetically better? Any pics?
Old Nov 20, 2009 | 07:54 AM
BKbroiler's Avatar
BKbroiler
Check acdelete.com
Old Nov 22, 2009 | 10:48 AM
Iggycat2009
Default Removal of AC Wiring for a 76 C3 and installation of AC Delete cover
Spoke with M & H Electric Fabracators and the wiring harness for a non AC car verses an AC car has connectors completely different that connect to the control panel in the console. The only way to remedy this is to cut back the unused AC wiring and tape it off on the firewall leaving the esential blower motor ground and power wire.
To add insult to injury the 76 AC contol is the only part avalible which I just bought. The non AC control is not availble. I looked at my neighbors 70 C3 non air car and the nose is currently off for full restoration. While doing a stare and compare I noticed the passenger side on his 70 has a vent cut out and my 76 does not. In order to add one, I would have to pull the fender and I'm not going there. The drivers side vent opening is the same on both cars. I figured with the T tops off, the windows down and the fan motor pulling in fresh air, the passenger should not roast in the summer..
I also noticed the original heater core in my 76 has the tubes facing downward and the new AC delete cover has little cut-outs at the bottom that appear to be correct and would fit the original configuration without requring a new heater core to fit the new cover. I'll call over to the the folks at AC Delete and make sure the original heater core will work with the new cover. I will advise.
http://www.acdelete.com/pages/68-82_Y-Body.htm
Old Nov 25, 2009 | 05:10 PM
Iggycat2009
Default Does anyone know if ACdelete.com is out of business?
After calling multiple times and sending e-mails, I received no response from this company. I won't do business like this. Does anyone else sell ACdelete covers? Does anyone have good used orginial non AC covers availble?
Mike
Iggycat
Old Nov 25, 2009 | 08:04 PM
Bigbuffer's Avatar
Bigbuffer
Just got last week my AC delete plate for my 1980. It took 5 weeks to get my kit. Very good product. High quality product.
Old Nov 25, 2009 | 09:50 PM
mydejavooo's Avatar
mydejavooo
5 weeks? Sounds a bit slow on the shipping there. That, combined with the lack of response to emails and calls, makes that supplier look a bit lackluster. Too bad there is only 1 company out there making those.
Old Nov 25, 2009 | 10:46 PM
Iggycat2009
I totally agree with this.. I wonder if the owner of ACdelete.com sells this stuff part time.
Mike
Iggycat
Old Nov 26, 2009 | 12:24 AM
mydejavooo's Avatar
mydejavooo
Mike
Iggycat
Could very well be, but it still puts people off when they fail to get responses to their inquiries. $160 isn't a whole lot of money, but it's still worthy of being taken seriously by the vendor. The better the customer service, the more likely you are to tell others about them. In this case...1 vendor....no alternate choices....leaves one with no other choice but to either make their own, or just wait (read that as HOPE) for the part to arrive. I guarantee you that if there were more than one vendor that sold these, he would look into either hiring someone else to help him, or simply change the way he does business. Heck, I get great customer service from guys selling a $2.00 part on eBay! Just my 2 cents.
Trevor
Old Dec 27, 2009 | 07:36 PM
vitosdeli's Avatar
vitosdeli
6th Gear
Default How did you do it?
Im trying to remove my ac from my 79 vette. Is there anything I should worry about? Or is it as simple as just removing everything that deals with the ac. I really just want to take out the compressor. Any suggestions???
Old Dec 27, 2009 | 08:02 PM
KeyWestJack's Avatar
KeyWestJack
Go ahead and remove it. Label the parts, store them away incase you change your mind/sell the car. Pay attention to your wiring, leaving no hot circuits that could ground (find the fuse and remove it).
Old Dec 27, 2009 | 11:36 PM
Iggycat2009
Default AC Delete C3
The way I'm removing my AC is in the engine bay. I ordered my AC Delete cover and pulled all existing AC components off the firewall. The only question I had was with the fan blower switch and the resistor could be installed underneath the new delete cover thanks to a fellow board member's picture. I would send you the picture but I guess I can't at this point (I'm a relatively new member here). If you would like more information send me a pm and I'll forward the picture to your e-mail.
I originally thought I could pull all factory AC parts out of the car but its entirely too intrusive with pulling the fenders off and adding vents and it didn't make much sense. I did a comparison with my next door neighbors 70 car w/o AC and the difference is considerable. He's doing a frame off and the fenders are removed and I was able to get a good look. You can still use the fan and fresh air controls with your current configuration when the engine bay parts are removed..
Mike
To removing AC from my 76 C3 - help
