performance help
Old Nov 19, 2009 | 10:42 AM
amf133's Avatar
amf133
Default performance help
i want to take apart my motor and clean out all the carbon deposit. while doing this i want to change the cam rockers and anything else that has ware on it? what cam is the best for a 1981 corvette? i am looking to just get a little more power out of it. just change the cam, get 160 degree thermostat and a different chip for the car for performance? what cam should i get and where can i get it? also what would be the best rockers, pushers exc. to replace in the motor?
amf133
Old Nov 19, 2009 | 11:48 AM
marz's Avatar
marz
Comp cams has many different cams for this motor. But, be sure you get matched rockers/ lifters/ springs/pushrods to do it right and get the best bang for the buck. Call Comp or Lunati and tell them what you have and what you want to produce. Are you going to do anything else to the block or heads? Remember if you do anything for more performance it doesn't do any good if you don't feed it and let it breathe. Headers and an intake will be a must have. But, ask them and get their opinion. Maybe I am getting ahead of myself since you only want to produce a little more power, but for less headaches match it all up.
