can someone recommend headers 1978
Old Nov 19, 2009 | 07:16 PM
bdw3031's Avatar
bdw3031
Default can someone recommend headers 1978
I am looking for long tube headers with ceramic coating for $400 max
Old Nov 20, 2009 | 10:14 AM
Dodosmike's Avatar
Dodosmike
Me too.
I've been looking for a while now, might have to expand my $$$$ range.
If you find any, let me know?
I'll do the same for you.
Dodosmike
Old Nov 20, 2009 | 10:55 AM
TPIShark's Avatar
TPIShark
Default Headers
Here's some choices from Jeg's. Some are under $300. I prefer Hedman. If I got another set, it would be with the ball-flange type collector. No more collector gaskets to change, and it would give you a little room for angle adjustment if needed:
http://www.jegs.com/webapp/wcs/store...=KeywordSearch
Old Nov 20, 2009 | 01:03 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
I installed Hedman ceramic headers on my '79, pretty sure these are the ones I ordered...
http://www.summitracing.com/parts/HE...6/?image=large
Old Nov 20, 2009 | 01:17 PM
Ganey's Avatar
Ganey
Both Hooker Super Comps & Dynomax Cerama-Coat Headers are excellent for perf. The Dynomax Corvette SB Cerama-Coat headers fit & flow great, much better than is commonly known. I have been rec. them & many have them now.
Old Nov 20, 2009 | 05:52 PM
bdw3031's Avatar
bdw3031
jegs said they did not make dynomax anymore and headman said they would not clear steering.What are you guys using and did you have any problems with the fit.I would like to order a set tonight. Thank you for your help.
Old Nov 20, 2009 | 06:56 PM
fauxrs's Avatar
fauxrs
I dont know anything baout Dynomax being gone, as for the Hedmans, the only issue you may have is one tube hitting the idler arm, this is easily resolved with a small dimple - I know - who wants to dimple new headers - cant argue with that.
They do clear the power steering however.
I run a set of Hedmans with the emissions tubes on my car for almost a decade now, the headers look just like they did the day I installed them.
Old Nov 21, 2009 | 01:16 PM
marz's Avatar
marz
Hookers are a perfect fit.
Old Nov 21, 2009 | 01:40 PM
C3 Stroker's Avatar
C3 Stroker
Hooker Super Comps....easy installation, perfect fit.
Old Nov 22, 2009 | 11:16 AM
rbat's Avatar
rbat
A few questions.
Will they work on a '75?
Are there headers available that match up to the exhaust without and mods?
Has anyone used exhaust tape, if so how much do you need?
thanks
Old Nov 22, 2009 | 12:26 PM
Wavbyby's Avatar
Wavbyby
Have you considered replacing your exhaust manifolds with 2 1/2" units? these are quite effective and you can still have the stock look
Old Nov 22, 2009 | 02:27 PM
C3 Stroker's Avatar
C3 Stroker
Originally Posted by rbat
A few questions.
thanks
Due to the different lengths of headers, there are none (that I know of so far) that bolt/match up to your stock exhaust......you will need a custom piece 1-2 feet long to connect to your system. Should have no problems with a '75......small block headers are listed to fit '68 to '82 Corvettes.
Old Nov 22, 2009 | 08:17 PM
rbat's Avatar
rbat
no I have not heard of this option,
where can you get a pair?
Old Nov 22, 2009 | 08:27 PM
marz's Avatar
marz
Mine is a 75 with Hooker Super Comps. Perfect fit, but you will have to have someone fit the rest of the exhaust for bigger pipes. I had a local Meineke guy make custom 3" pipes for mine.
Old Nov 26, 2009 | 02:21 PM
bdw3031's Avatar
bdw3031
bump
Old Nov 26, 2009 | 06:28 PM
Golden's Avatar
Golden
Sorry for the slight thread hijack but a question for the guys running ceramic coated headers.
I notice warnings on any of Holley brand headers that it says ' do not break in an engine with new headers, it will damage the coating', any idea what they mean by this?
Old Dec 2, 2009 | 11:34 AM
rbat's Avatar
rbat
is this true?
Old Dec 2, 2009 | 05:44 PM
wan2run's Avatar
wan2run
This is refering to a new or freshly rebuilt motor. The temps can get higher than the coating can handle.
To can someone recommend headers 1978
